Joanbcn
DJI Thor Posted at 2020-4-19 01:50
After testing, Ronin-S can normally provide stabilizing functions for cameras with the weight is less than 3.6KG, width does not exceed 205 mm, and the height does not exceed 150 mm. As Canon 250D is not listed on the compatible camera, the compatibility is yet to confirm. The list will be continuously updated, you can fill in the compatibility request at https://www.dji.com/support/compatibility.
Cuando será compatible con canon eos250d? |
