JohnLietzke
Flight distance : 3125968 ft
FCC and CE are to entirely different matters than the frequency range 2.4Ghz and 5.8Ghz. The frequency (2.4Ghz & 5.8Ghz) is the wave length that the signal is sent and received on. Different frequencies have pros and cons typically pertaining to data transfer capacity, signal range and signal penetration.
FCC & CE for Dji Drones use the same frequencies 2.4Ghz & 5.8Ghz. But the transmitter power is greater for FCC which typically results in a stronger signal with superior range.
CE mode is <=20dBm (100mW)
FCC mode is <=26dBm (<400mW)
THe Ukraine would have to adopt the FCC protocol or create a exemption.
