Harpermike
Flight distance : 11447 ft
InspektorGadjet Posted at 4-24 11:21
Since the Drone is actually quite far from the ground and deformed perspective elements, the use of a drone for AEB and HDR is actually very useful and easy to do... if you in the ground, the lightest movement makes things which are close to the camera get deformed very fast... but not up in the air...
For my own experience, it works fantasticly well, the only problem is that it takes time to do it manually, so if clouds or other elements are moving fast, it ruins the shot... an automatic AEB mode would help with making this process much faster.
Thanks. I hadn’t reckoned on the distance from the subject being so great. Thanks. Now I am pulling for AEB, too, in the next update. |
