Mavic Mini Release Notes (04/23/2020)
123456Next >
36866 213 2020-4-23
DJI Support
Flight distance : 2408 ft
Overview:
Date: 2020.04.23
Aircraft Firmware: v01.00.0500
Remote Controller: v01.00.0500
DJI Fly App iOS: V1.0.8
DJI Fly App Android: V1.0.8
What’s New?
  • Added manual exposure for videos (requires DJI Fly v1.0.8 or later).
  • Added 2.7K 24fps and 1080P 24/48fps resolution (requires DJI Fly v1.0.8 or later).
  • Added manual white balance adjustment (requires DJI Fly v1.0.8 or later).
  • Improved download speed for photos and videos.
  • Improved flight stability in some scenarios.
  • Added support to adjust operation frequency in Ukraine.
  • Optimized remote controller performance. Calibrate the remote controller if it is beeping after updating the firmware.
Notes:
  • Note that the update may reset various main controller settings, such as the RTH altitude and the maximum flight distance, to default settings. Before updating, take note of your preferred DJI Fly settings, and readjust them after the update.
  • If the update fails, restart aircraft, remote controller, and DJI Fly or DJI Assistant 2 for Mavic, and retry.
2020-4-23
ABeardedItalian
Flight distance : 1063107 ft
Yay, new fw to play with.
2020-4-23
sbonev
Flight distance : 3665279 ft
Switzerland
You forgot to add that the intelligent battery firmware is also available...
2020-4-23
hallmark007
Flight distance : 9827923 ft
Good job, let’s see if it can straighten the props ;+)::::::
2020-4-23
Deucalion
Flight distance : 103091 ft
hallmark007 Posted at 4-23 02:22
No, that requires a firmware upgrade to the carrying case.
2020-4-23
Montfrooij
Flight distance : 2560453 ft
Thanks for the info!
2020-4-23
hallmark007
2.7k 24fps now that’s a result.
2020-4-23
djiuser_CZms4IiY5rKV
Flight distance : 498399 ft
sbonev Posted at 4-23 02:20
How are the batteries updated, and how can you tell if they have updated?
What version are they on to now - how check to confirm all updated?
Thanks
2020-4-23
hallmark007
Deucalion Posted at 4-23 02:29
Darn it....... next update so......
2020-4-23
Guorium
Flight distance : 513061 ft
Ay yo this is the bomb update! Let's see if we have more uncommanded descends. Then maybe a follow me and raw. Then you can leave the mini behind and never touch it again lol
2020-4-23
Renato61
Flight distance : 168163 ft
Raw support not present?
2020-4-23
hallmark007
Renato61 Posted at 4-23 03:07
Think it was a joke, you won’t see raw ever with mini, but jpegs render very nicely and it is quite possible to manually improve photos even these jpegs, I don’t think there is much more to be extracted from these photos that are going to make big improvements, most modern cameras process jpegs really well.
My tip is try to follow good light this will improve your photos a lot more than Raw will .
2020-4-23
dronespilot
Flight distance : 1392995 ft
Manual video exposure
2020-4-23
Thalisbl
Everybody asks for RAW like it is the holy grail of photography. I mean 90% of the population takes photos with mobile phones and jpegs. I understand to ask for Raw if you are proffesional (or even serious  amateur) videographer or photographer but DJI has other devices for such market. Mini is for just amateurs and the quality of video and photos you can get with it are quite impressive. Sure we would like RAW but we can easily live without it :-)
2020-4-23
Deucalion
Definitely appreciate the availability of manual camera controls with video.
2020-4-23
fans1cafe718
Flight distance : 230 ft
Thalisbl Posted at 4-23 03:47
Agree very much
2020-4-23
djiuser_zHKw0MQPeMy6
Flight distance : 16775 ft
After the upgrade. The controller  keeps beeping.  What to do?
2020-4-23
Cal Evans
Flight distance : 85673 ft
ww00t!w00t!
NEW TOYS!
=C=
2020-4-23
hallmark007
djiuser_zHKw0MQPeMy6 Posted at 4-23 04:00
Calibrate controller, instructions in your manual.
2020-4-23
fans1cafe718
The release notes say:
2020-4-23
Corger
Is there anything new that is not mentioned in the release notes?
2020-4-23
fans1cafe718 Posted at 4-23 04:06
I did the calibration,  won't help. Still beeping.
2020-4-23
hallmark007
djiuser_zHKw0MQPeMy6 Posted at 4-23 04:18
If you did calibration correctly, it should have stopped once you rebooted, I can only suggest go to dji assistant and revert back to last RC FW and redo new FW, I know it’s a pain but if FW is not 100% it might come back on you.
2020-4-23
djiuser_b5bNHKOWysop
Flight distance : 43862 ft
Greece
Controller Calibration Process
Step 1: Turn on the DJI Mavic Mini remote control.
Step 2: Then open the DJI Fly app on your smartphone.
Step 3: Connect the remote to your phone via WLAN. The RC should be factory connected to Mavic Mini. If not, follow the instructions on page 38 of the DJI Mavic Mini User Guide to connect the RC to your phone.
Step 4: Click Close in the "Indicates that this attachment may not be supported" message.
Step 5: If you check the lower right corner of the DJI Fly app, the message "RC Connected" appears.
Step 6: Click Input Device.
Step 7: Click General Settings (3 dots) at the top right.
Step 8: Select the Remote Settings icon on the left.
Step 9: Click on "Remote Calibration" at the top.
Step 10: Next, you should see 2 square boxes for each Mavic Mini remote panel.
Step 11: Click "Start".
Step 12: Before you start, read the warning and ask to place the joystick in the middle.
Step 13: Click "OK" in the warning.
Step 14: Follow the instructions on the screen to slide the joystick.
Step 15: Follow the empty blue circle on the screen to surround the entire blue circle around the screen.
Step 16: It starts more or less from the top and then moves to the right, down and left.
Step 17: Then repeat the process with the correct Mavic Mini joystick.
Step 18: Then follow the on-screen instructions to calibrate the left DJI Mavic Mini dial.
Step 19: Calibration is now complete. Click Yes.
2020-4-23
Pashi
Flight distance : 4862598 ft
Russia
Oh My God!!! DJI! You're THE BEST!!!! It's pleasure to deal with you. You promised to add manual controls - you did it. This is why I love you. THANK YOU!!!!!!
2020-4-23
DowntownRDB
Flight distance : 1722 ft
Nice firmware update.  Thank you.
2020-4-23
crash1sttime
Flight distance : 1047503 ft
DowntownRDB Posted at 4-23 04:53
Is this where you can tap the screen to decide what you want to set the exposure level to ?
This works in photo mode but still doesnt work for video mode  in the Android or IOS version of the latest app.
Also I lost the satellite counter on my samsung S6, I had to uninstall/reinstall the app to get it back.
2020-4-23
After remote controller calibration,  beeping stopped.
2020-4-23
JHa
Flight distance : 99797 ft
Czechia
Is there other device with MM weight, size and battery life and with raw? Or raw possibility depends in dron size?
2020-4-23
Donsir_LTU
Flight distance : 1043940 ft
Lithuania
Hi, I just tried the new software ... everything looks fine, so I want to say THANK YOU DJI. Just one question ... Can anyone try Quickshot CIRCLE mode and try to select a distance of 10m, 20m ... Please try several times. I can choose circle mode, but I can't choose a different distance in meters ...
2020-4-23
Guorium
The same can be argued since RAW is made first then converted to JPG, it is little work to keep raw for mini's software. What I really wonder is, for mini's sensor size, it RAW really going to make that much of a difference? Mavic Air has the same sensor size, do Mavic Air users find raw a big deal?
2020-4-23
CaulfieldS
Flight distance : 117405 ft
Anyone know if this fixed the gimble adjusting down when coming to a stop?
2020-4-23
Thalisbl
Guorium Posted at 4-23 06:09
RAW is always the best choice, no matter the size of the sensor (with some phones you can have RAW files with some photo programs as well). It is like you have the negatives (for us the olders) of a film shooting. With more dynamic range and ability to correct your photos without loosing any data, raw is something must for proffesionals. For the rest of us though jpeg is adequate. Myself if I want to have the best quality from a jpeg (apart that I pay more attention when I actual take the photo) I saved it first as TIFF and then manipulate it. I don't gain anything in quality but when I manipulate TIFF and save various versions of a photo I don't loose what ever quality had in the beginning either
2020-4-23
TDZHDTV
Flight distance : 2068550 ft
Corger Posted at 4-23 04:10
AE stays locked now in Quickshots
2020-4-23
Francoisd
Flight distance : 66352 ft
It has to be confirmed by someone else, but in video mode, when you tap on the auto button on the right bottom corner, you access to manual parameters for video I think. I'm not familiar with manual parameters on video but it seem to be like my canon camera.
2020-4-23
Deucalion
I won't lie, on my full frame Cannon 6D I always use raw. The JPG it outputs is good, but RAW preserves more detail. I am not clamoring for raw on the MM, though I would welcome it. I think it is a marketing thing. And it does cost 1/2 the price of a MA and 1/4 that of a MP.
2020-4-23
Guorium
Thalisbl Posted at 4-23 06:42
Why can't you just make copies of jpg and keep the master file untouched?
Also, editing raw is not that much pro. I am sure if newbies and see a clearly better image after edit than jpg then they would like to play with those slider bars too. Easier than changing mini's firmware to keep raw file.
2020-4-23
TDZHDTV
Donsir_LTU Posted at 4-23 06:06
Didn’t test that, but AE lock now stays on in Quickshots
2020-4-23
TDZHDTV
crash1sttime Posted at 4-23 05:40
Tap the Auto button in the bottom right hand corner
2020-4-23
Guorium
Deucalion Posted at 4-23 07:04
It is a marketing thing for sure. I have raw file made on my 6d when it comes to serious shoot. Other than that jpg is ok.
2020-4-23
123456Next >
