DJI Gamora
Hi, there. The RTH function for mavic mini is straight back to home. Please always pay attention to the aircraft flight screen image and aircraft position during the RTH to make sure the aircraft is safe. If something goes wrong, you can press the “X” icon on the left of DJI Fly, or press the RTH button on the top left of the remote controller to cancel RTH. After the RTH is canceled, the aircraft will hover at its current position. In this case, you can control the aircraft manually. Please fly carefully and do not initiate RTH again until the aircraft is in a safe environment.
Please check the logic of RTH as follows: https://dl.djicdn.com/downloads/ ... _Manual_v1.0_EN.pdf
