Sorry for the trouble with the new firmware, please double-check whether the propellers are damaged or cracked. If not, we will need more details for analysis.
1. Flight Controller Aircraft Data:
(1) Download DJI Assistant 2 from the official website. Download link: https://www.dji.com/mavic-mini/downloads
(2) Launch DJI Assistant 2. Within 20 seconds after the Mavic Mini is powered on, connect it to DJI Assistant 2.
(3) After DJI Assistant 2 recognizes the aircraft, choose "Log Export", and then click "Save to local".
(4) The final exported data are ".dat" files.
2. The specific time when the error happens.
3. The corresponding flight records.
Android device:
Connect the mobile device that has been connected to the aircraft to the PC, and then export the "flightrecord" folder.
iOS device:
Connect the mobile device that has been connected to the aircraft to the PC, open iTunes, and then export all data under the "flightrecord" folder.
Once you export the required logs, please upload to Dropbox or Google Drive and post the link here, thank you in advance. |
