djiuser_X4rXCZXsvxzg
Flight distance : 4110699 ft
Slovenia
Just to add some of my thought about all the things around props.
Right before the new FW came out, I noticed "not enough force" warning during the one of the flights - let me add, that if you're a beginner in drones as I am, it is very easy to overlook those warnings. Landed immediatley and uploaded all of my flight to Airdata to see, if there were some warnings before that flight (up to that point I had about 5 hours of flying). Fortunatley that was the only flight with warnings (4 of them, noticed just 1) so I did another test flight at low altitude with very low wind, where there were no further warnings. Well, that didn't make me worry any less so I bought new props (all 8 of them, as I only now realized that there are only 4 spare props that came with MM). Just checking the markings on the old and new props, I realized that they don't "match" so I decided to go and change them all. Just as I took the old props off and compared them with the new ones, I noticed that, if you put them next to each other (on the flat surface, pressing the both axis) the curvature of the old props was flattened. This is not seen with a naked eye, but only with direct comparison. I know there was a picture of that kind of comparison somewhere on the forum, to bad I didn't took a photo myself.
I went further, because I wanted to find out what made props flat. About two months ago, I bought a bag for MM as I didn't buy the Fly more combo. The bag has foam inside, with holes made for RC, AC and extra batteries, all fits nice and tight. But as I came to find out, the back props were pressing on the foam, which was seen as a dent in a foam. There is no way to put MM inside the bag in the way that props wouldn't be presured. SInce then I have not yet find the proper way to store MM as I wish, but this 3-D printed stand looks perfect.
To me, it seems obvious that flat props can't give you enough lift. As to the ones that are asking, why uncommanded descends and/or motor warnings came in the middle of the flight - at the start of the flight we usually all have full batteries, and when voltages come down and with addition of slight differences in wind conditions, "wild" things can happen with Mini, as it is so light. I will still be cautious in observing as how the Mini behaves, analyze all the data I can and consider all the warnings I get. I hope it will be enough to keep me out of any trouble. |
stand
