ABeardedItalian
Flight distance : 1063107 ft
Those tests prove nothing whatsoever about bad batch props or faulty props you have been hammering around here. Both those tests were done with props that were damaged by those who done the tests, in one case they were so badly damaged because tester placed them in a book and jumped on them.
I don't know about Sar's test but mine were never to prove a bad batch of props, the question started when many users had the warning on rear left and I was curious as to why. On initial review I found the beginning of an RPM Increase and a difference forming, that's when I began testing and found my replacement props performed better then my originals.
Your imagination ran away with itself. There is no need to prove bad props cause problems everyone knows this they don’t need a test, so the test only proved what we all knew. Bad props are just that.
Not everyone knows this, you yourself have gone around to say that props are not the cause of UD when our testing says otherwise, yes I'll give you ours are extreme cases but it identifies that props do play a role in them.
So on to your claim of bad props that look exactly like new props in every way shape or form. Where is the test that so called props caused craft to descend of it own volition, well it’s easy no test no proof just your delusions .
You say they’re props that are brand new causing craft to descend on its own, where is your proof or are you just making this up.
How do you KNOW they're isn't an issue, if DJI didn't believe there was an issue why is there a warning, why did they make a post addressing it. They have information to say otherwise.
There have been warnings which dji have set up on motors, but maybe you’ll explain how only one motor the same one detects bad props and this detection magically goes away when updated FW on assistant.
No one magically fixed the issue, those users who had the problem resolved via a fw refresh are still unknown. It could of been a bug due to incomplete installation, we have see that those who do get the warning for real that changing the props does fix the issue.
And still we see no drop outs not even slight ones.
Please explain why no warnings for some and after 3 flights they get a warning to change prop and low and behold it’s left rear.
Don’t you find that a coincidence, also is it not a coincidence that those who didn’t change props or simply swapped props, not one single problem with descents.
This warning isn't tripped willy nilly, the users who haven't expired the warning again simply haven't met the same conditions as the first time the warning was issued. Why do we get high wind warnings only when it's windy, because the conditions have been met to trigger the warning.
I think at first I thought props might have been the problem, until I’ve been reading that people purposely damaged their props to prove nothing except damaged props cause problems, and in these cases props were very much visibly damaged.
Again what visual damage do you see? I'll destroy a fresh set of props to prove the same thing, we can't see the damage that is taking place and if you can't grasp that then all of this is pointless. Can you see how hard Steel is? Only when you test with a file can you determine it's HARDNESS, you can't see the molecular structure that has changed. Just like plastics, when the props are bent past a certain threshold they lose there strength. If the resin was impure, if the mold had defects, if the mold release reacted with the plastic, if the stresses from manufacturing weakened the props. All things we can't SEE but could take place that would cause props to fatigue.
I wonder if you asked any new user even a complete green user, if he has visibly damaged props what does he think will happen, cmon what do you think he might say ! I can guarantee you he wouldn’t need any test to prove his answer.
What if you told that same user to just un bend and straighten his props and that everything will be okay... oh wait DJI is already telling us to do that.
I think it was the complete ridiculousness of saying it’s was something that couldn’t be seen, something something that needed an x-ray or needed to be put through an ultrasonic that convinced me this was more than a prop problem.
No one has said this is strictly a prop problem, it was the props though that started the questioning that lead to the discovery of UD.
So far we’ve seen some get warnings as soon as they change left rear prop or update FW warning doesn’t come back and no one is receiving warnings to change more than one. So if your theory is right all bad props magically ended up on left rear and you don’t think this is far fetched.
We don't know the answer to why this is, from my testing both rear props were experiencing issues and not everyone has reported just the Rear Left, there have been reports of Front right and Rear Right. We can only guess the conditions are not the same as the flight that triggered the warning in the first place, we need DAT files instead of guessing.
What happened with last FW was better optimizations and a warning to change bad props, but the cause of descents was not down to only invisibly damaged props, dji have now come out and said to check for damage to props and never mentioned anything about invisible damage or having them X-rayed, physical damage, in fact they mention if damage can be repaired then do this, I mean does that sound like they’re worried about bad batch of props
You're still holding on to jokes like those are serious statements, while said jokingly they do hold some truth because damage CAN take place that we can't visibly SEE. DJI has Identified an issue with props, has made a suggestion to try and if the warning persists to REPLACE the props. Clearly they are aware that bad props do exist.
I think it’s pretty clear what both Abearditallian and SAR did to the props, you’ve now lost the plot altogether what your saying is they damaged them invisibly , by jumping on top of them etc, it’s like been in the twilight zone now with you, you tried this with the pitch on the mini until Abearditallian proved your theory wrong on that one. Now your making all sorts of ridiculous statements about props.
Was destroying them the only thing we did? What other tests would you of liked to see, oh that's right you've suggested nothing and call us insane for bothering to figure out what's going on. We tried various things that are plausible causes and when the results weren't what we were looking for we tried more aggressive methods till we got the result we desired. Just because it took the destroyed state to provoke a response, we did get a response that provided us with FACTUAL information.
Look think about what you’re actually saying, they’re are bad batch of props out there, but they somehow only find their way on to one motor and it’s this single prop that’s responsible for uncontrolled descent.
“Tips are paper thin you’ve seen them flapping around”
So can you just explain how all these flapping props found their way on to one motor ?Why are there no flapping props on the front motors ? Why have 3 props got no problems with these 1 degree out of tune rear left props ?
......... GJ's graph, mine, and Sar's all show RPM difference across all props. I've changed ALL props and have shown the differences, it's not just the Rear Left motor but the error does seem to prominently show up in that motor but as we've seen from previous reports that it's NOT THE ONLY MOTOR to report the error.
If props are so problematic why have we not seen this on other dji craft ?
What other DJI drone has props this small, oh the Tello which is an indoor drone that doesn't experience the forces or temperatures/conditions that the Mavic Mini does.
And I suppose why were the two tests not done with these problematic props instead of putting unnecessary pressure to flatten them or jumping up and down on them.
It's funny, two people who don't know each other. Had no clue others were doing the same testing, on separate forums had the same idea to do testing to see if messing with the props could provoke an UD. Seems really suspect that if there was no issue that people wouldn't of had to do any theory testing as to why these problems exist. Except we did, and they found the cause of UD, I found you can overwhelm the FC. I'm sorry the cause to you can be thrown out as being worthless and doesn't provide any actual information but you don't go on to say how we could, what tests we should do, how we could provide this information. I just see you going round and round forcing your opinion on other people and anyone who thinks outside the box is inherently wrong.
I have nothing to prove, I don't have an agenda, not forcing my thoughts onto anyone. I don't work for DJI, I don't honestly care after all of this, but I was curious and went through the trouble and effort to test because I wasn't getting answers here. Call my testing rubbish but I've learned a lot about the mini, I would like to think that all this discussion has helped DJI to see what's going on but that's fruitful thinking at this point.
