120ccpm
Flight distance : 1396755 ft
grahamjohnson10 Posted at 4-27 06:53
There have been many reports of uncommanded descent of the drone due to rear propeller failure as well as the new error message in .500 firmware of a motor speed error.
I was flying yesterday when I received the motor speed error caused by deformed propellers on the rear left motor.
Excellent analysis, it fully confirms that the issue is with the props, which lose pitch causing high RPMs. The new firmware simply throws an alert when it sees a motor spinning substantially more than the others, and instructs the pilot to replace the props on that specific corner. It's very simple, and very smart. As I said in previous post, it's the same principle that some TPMS (Tire Pressure Monitoring Systems) use, relying on ABS sensor to detect wheels that are suddenly rotating faster than the others (because of a flat).
Now we really need to see if this will prevent uncommanded descents, but I think it will, everything makes a lot of sense.
To those who say the error "goes away" with a restart: it might simply be that your props are near the error threshold, and external conditions/factors might push it above or below that. Refresh your firmware via DJI Assistant to make sure everything is fine on that front, then if you see an error, even intermittent, replace the props. |
