hallmark007
Flight distance : 9827923 ft
120ccpm Posted at 5-26 10:58
If you find that you have a perfectly good prop but still get warning, either update FW on dji assistant or change prop both of these solutions are proven to work and no problems have resulted in carrying these out.
I applaud your sound logic: if you have a perfectly good prop [...] change prop.
There you go again, I think if you read many posts above you will see many who have had perfectly good prop but got warning, similar to Mavic Air1 perfectly good compass but get warning to calibrate, it’s quite common with these drones to get false warnings.
The problem with telling others to do hover test is to then try convince them they need to change a perfectly good prop. And yes I know I have told them to change a good prop, but because they are anxious to get flying and it’s a simple fix to get going. Your test hasn’t helped anyone, improvement in FW is what has made the difference to this drone, but ignorance on your part trying desperately to convince others their props are invisibly damaged, this test requires testing indoors not outdoors flying normally, and if you read the answers given they are so diverse and explain very little, the test hasn’t shown to improve any flying, but if one was to read through the mire of different opinions, confusion is all new users would be met with.
I find it ironic that the prop crew still refuse to admit that improvements other than props are resulting in a much better flying experience for all mini users, it’s like something’s stuck in the craw of your throat “desperation” . Just accept it props didn’t cause uncontrolled descents and trying to convince others particularly new users that somehow invisibly damaged props are going to cause their drones to fall out of the sky is ridiculous and totally unfounded, and it’s clear from djis message that if props are not visibly damaged they are not damaged. Get over it, move on to your next folly.... |
