Zbip57
hallmark007 Posted at 5-29 07:00
It seems being a smart @ss and writing complete untruths is now what you have sunken to.
1/Never told anyone to ignore warning, but to follow djis instructions
Evidently you are incapabable of providing proof for anything you say.
"1/ Never told anyone to ignore warning, but to follow djis instructions"
You have on numerous occasions stated that the Motor Speed warning is not reliable, and that in your opinionthe warning is the result of defective software. You have repeatedly posted your opinion that a visual inspection is sufficient to prove the blades are "perfectly fine".
"2/ Your indoor test could be done with any or many different drones and similar results will come about."
Well, duh, yes! That's exactly the point of the hover test. It is a valid and repeatable simple test, the results of which document the relative health of your propeller blades, regardless of which drone you currently fly.
The purpose of the Motor Speed warning is to warn you that your propeller blades are not producing sufficient lift. The motor needs to run at abnormally higher speeds to compensate for that lack of lift. Eventually the motor will reach a point where it is no longer capable of running any faster. That's when you'll see drones dropping from the sky.
The Motor Speed warning, is a "warning". It is a preemptive warning to tell you it is time to inspect or replace your prop blades. You say, if they visually look okay, that means they're "perfectly fine". The Mini may continue to fly perfectly fine and you may not encounter the exact same conditions again which triggered the Motor Speed warning. None of that proves that the blades themselves are in fact "perfectly fine".
The Motor Speed warning is an explicit indication that something is amiss, and it specifically identifies the suspect motor telling you to replace those propeller blades. You can trust your cursory visual inspection, or you can do a simple hover test to find conclusive evidence of whether or not that motor is spinning faster than the others. The simple test can be done with any drone capable of recording motor speeds as part of its logged flight data. If you prefer, you can even do the hover test outside if you're too afraid to trust indoors the "real improvements" in flight stability from the latest firmware update which you keep harping on about.
"3/ Almost everybody has ignored your plea to test and yet no problems showing, [...]"
It's not a plea. It's a suggestion. Whether you choose to verify the condition of your props via a visual inspection or via an actual physical test, is nobody's business but your own.
My only objection is to your continued nonsensical insistence that the Motor Speed warning is invalid, that it is a software defect, and that it can be dismissed with a simple glance at your props if they show no visible damage. The fact that the Mini may continue to fly normally, even after receiving a Motor Speed warning, only indicates that the props have not yet surpassed a critical level of deterioration. They may continue to fly fine for now, they even might not trigger another warning, but their condition has already degraded sufficiently to have triggered this warning.
Do a visual inspection and you're only guessing. Do the hover test and you'll know for sure.
"3/ [...] many say they are scared to fly because the “prawn sandwich brigade” insisting that props are bad even if they Follow dji's instructions as laid out at top of forum."
You keep referring to those instructions, while continually misrepresenting what they actually say. Here's a link so others can read the actual instructions for themselves. What they say is this;
- When the propellers are bent or damaged, the aircraft propulsion may be reduced and not perform as intended. The new Mavic Mini propeller safety inspection feature is capable of detecting this and sending a notification to the pilot with a “Motor Speed Error” message.
- Please land the aircraft as soon as possible and check if the corresponding propellers are visibly damaged, bent, chipped. If the propellers are slightly misshapen, can straighten them out and retest to ensure the issue has been resolved. If the propellers show signs of major damage, chipped or bent, please replace them before flying.
DJI's instructions say that the new firmware is capable of detecting whether propellers are under-performing. Nowhere does DJI say the firmware is defective or unreliable. DJI says to inspect for visible damage, attempt to straighten, replace the propellers. Nowhere does DJI say that a visual inspection following the Motor Speed warning can be interpreted as meaning the firmware is defective and that the props are "perfectly fine". Your opinion is not supported in any way by what DJI actually instructs.
The Motor Speed Error message in DJI's Fly app says, "Motor speed error. Land or return to home promptly. After powering off the aircraft, replace the propeller on the beeping ESC. If the issue persists, contact DJI Support." Nowhere in that message does DJI say, oops my bad, this firmware is obviously defective and your props are "perfectly fine".
You say, "It’s probably time to stop scaremongering and advise users to adopt manufacturers instructions".
You are the one responsible for continually spreading false information. You are the one telling people to continue flying on props that DJI has detected as being suspect. You are the one telling people that if the props visibly look okay that is somehow proof that DJI's firmware is defective and the props are "perfectly fine".
I am saying there is a simple hover test that anyone can do at any time to definitively confirm for themselves whether the Motor Speed warning is valid or not. It is not scaremongering in any way. It is a simple scientific test to either reasure yourself that your props are indeed perfectly fine, or that they are need of replacement. A visual inspection is not sufficient to prove anything.
"It seems being a smart @ss and writing complete untruths is now what you have sunken to. [...] “prawn sandwich brigade” "
Whereas you have sunken to calling people names...
