InspektorGadjet
Flight distance : 439915 ft
Ok so just as an update in the whole DJI Care Refresh experience... I just only created the ticket for the return and I already can say I dont like this AT ALL...
Firstly, conmunicating with tech support people. Not clear at all, very poor english.
Secondly, the tech guy says first replacement will be 40€ second 49€, even when absolutely nobody has seen the AC yet... I told him only front arm cracked, he said is their policy... so yeah since a replacement arm is 11 dollars, the fix is already going to cost me 39 (Care refresh) + 40 = 79 euros for only a broken front arm.
Thirdly, the guy ask me to remove the proppellers if they are OK, how can I know after a crash if they are Ok and not deformed? I said, well, how do I know, he says "check for dents" but nothing about being compomised or deformed... I also told him, that the manual clearly states to not reuse the propellers, once removed, get rid of them... so how on earth are they going to ask me to remove them?
Fourthly, asking about how to return it, what box, gimbal protection or not... not clear at all, only said no battery or SD card... is it really that hard?
Then I also noticed this just before cloicking "submit" DJI might charge a damage assessment fee of 50 Euros per hour if you refuse to repair your aircraft after being quoted.
And this: 2. If UPS loses your package, you should contact UPS yourself, and you might bear the loss depending on UPS' policies.
I suposse if you literally destroy the drone, is worth it, cause the repair alone would cost more than the drone itself... but also 50€ per hour? really? |
