speed_freakz
Flight distance : 569852 ft
Thailand
120ccpm Posted at 6-26 14:06
Test is supposed to be done indoor (without prop guards). All you need is good light, so that the Vision System can keep the AC steady. Auto take-off, 2 minute hover, auto-land, never touch the sticks, then analyze DAT with CsvView. If you export to Excel, use the formula =AVERAGEIF(A:A, ">8000"), where "A" is the column with the RPMs, to filter out values when the AC was on the ground.
And yes, purpose of this test is exactly to confirm whether your props are not performing well (not generating enough lift) or if there is an issue with the firmware.
Tried tests 3 times, but my app doesnt record any flight data. I disabled the sync data. Tried clearing all cache then tried again. No luck. Gonna try to uninstall the app and install again to see if it helps.,
Edit: No luck. It records jsut text files. dat folder is empty.
