Deucalion
Flight distance : 103091 ft
greybeard Posted at 4-30 18:39
Not sure what you mean by refresh. What happened was: I followed the instructions on the screen when the dji fly app told of a firmware upgrade. It took awhile but then when the aircraft rebooted, or just by itself, the controller started this loud, persistent beeping. I thought it might have been the low battery warning, but the thing showed lots of power on the LEDs. A message came up on the screen that was all in Chinese and would not go away until I touched it. Could it be the thing was hacked and bricked? Not sure, but enough for tonight. I have work in the AM so must get going. thanks for the help. BTW where would I go to buy a new controller if that is the issue?
These are the steps for DJI Assistant...
1. Start DJI Assistant on PC (or Mac)
2. Power on your Drone
3. Plug the drone into a USB port on your PC (You must do this within 20 seconds of power on your drone)
4. It should connect and you can then click the firmware menu selection on the left.
For the controller, basically the same steps.
The batteries will update when you plug them into the drone and power it up and connect your controller.
If your controller is bricked, contact DJI and open a ticket. |
