lingerakgmail.com
After many more 360 panorama pictures, i'm really annoyed by the app settings. The Ronin-SC is doing it's work fine, but it's just so hard to keep the right settings in the app. If you put your angle on 360, no matter what setting, the last image will have big overlap (means: is almost the same) as the first image of a row. it seems it doesn't take into account the overlap of the last image with the first image?
It's as good as impossible to keep settings between two shoots.
I have one camera and one lens, all i want it is to divide a circle into 6 rows, and 3 columns, maximum angle, (maybe only get a little off the top angle to not have too much air), and shoot.
the mavic drone does exactly that, i get perfectly even spaced pictures from it which are easy to stitch. why not apply the same logic to the Ronin software?
I hope some day my wish of steady shoots, that are the same each time without guessing and fiddling with dots on a screen, comes true. a very simple change in the app could do it.
d
