Paride Musci
Flight distance : 6103757 ft
Switzerland
In recent days I have seen many posts regarding batteries of the mavic 2 swollen and crashes drones, so I want to sharing my experience with you.
I own a Mavic 2 pro since 2018, you know I have almost always flown in the mountains, on the lakes and sea, in the fog and even with light rain when happened to fly in bad weather and strong wind.
Yesterday I checked the charges of the batteries, battery n°1 I had charged it 41 times, the n°2 - 39 and the n°3 - 47.
Maybe from tomorrow all three batteries will explode and I will also make a post about it, pitying my drone fallen from the sky, I hope not...
But I want to share with you my storage method which has worked so far.
This is what I usually do:
-I always store and transport my batteries in fireproof cases with silica gel bags inside. It is clear that when I am hiking I have batteries inside the cases that slow down the temperature change and the silica gel bags that retain humidity help. And then I never leave the batteries attached to the drone when I'm not using it.
-If the battery charge is <30%, I always charge it even if I don't have to use it for a month. If the battery charge is >30/40% I charge it the day before using it. I fully charge all the batteries partial charged the day before I will use them.
-I never drain a battery below 15-20%. Some completely discharged the battery (not in flight ...) to extend its life, I never did and I can't tell you if it's a right or wrong thing. Maybe it would be good if I do it too or maybe not, I don't know.
-I don't know what temperature I have at home exactly. I keep them in my bedroom, in a drawer of the desk, then at home and not in the cold/hot temperature in the garage, in the cellar or in the attic, or in the hood of the car...so to speak.
-The automatic discharge time is set to 10 days, so if I do not use them by the following weekend, the batteries go down to a safety charge.
-I'm sure there is no need for me to tell you not to use car chargers if you turn off the engine while charging, not to use third-party chargers but only the original one and not to recharge a still hot battery just discharged, and that it is not good to leave the batteries in the car in the sun while we are cooling off by swimming, it's right?
This is what I do, it is not said that it is right or that it is the best.
I hope I have been helpful.
Tell me about yours
