OscarM
Hello DJI FPV pilots
I am using the latest firmware in both the Air Unit and Goggles. (v01.00.05.00 )
The Air Unit is used for my FPV Car.
I have GPS module setup to the FC. (Matek GPS & Compass M8Q-5883 and Matek Flight Controller)
The FC is running the BetaFlight 4
I can see the GPS speed, Alt. Long. changes when the vehcile is moving but the home point direction and home point distance does not move (always pointing down and zero meter)
I do see from my goggles that I have 11 satallites and have let it sat for over 10 mins idle to make sure its lock
Apart from displaying GPS thru the OSD, the FC is turn off in accelerometer. I don't use to arm the throttle. The RC car has it's own R/X, ESC. The FPV setup is pretty standalone.
I also change the setting to 'set gps_rescue_allow_arming_without_fix=on'
Please advise what other setting I need to change in BF in order to get the home point direction and home point distance enable?
Thank you,
Oscar
