Moon landing
Flight distance : 4065 ft
Thailand
Bought Mavic mini 6 months ago,and have not updated firmware
I fly my CE Mavic mini in FCC mode.
Initially set with android phone and fake gps to USA, I put it in manual 5.8 on 149, you are in FCC if 11 numbers ,as CE has 13...…I now fly with iPad, with no need to use fake gps.
Start mini and remote with iPhone or iPad “NOT” connected to remote, as soon as remote connects to mini, (4 solid lights) pull back both controls to start props,only then connect iPhone/iPad to remote, finally you MUST push left stick up to take off...not DJI fly takeoff on screen
Landing..you must remove cable connection to remote ,just prior to landing.
After landing switch off power to remote and mini.
If you forget, you will have to reset with android.
I fly in 5.8 mode with silicon brass rod yagi’s over semi rural land, which does have WiFi interference breakups on some parts of the flight path......I can reach 3,500 to 4,000 meter depending on the weather
Been experimenting with yagi parabolic together, that so far set my longest distance, away from any buildings,I’m sure I could go further.
I have not updated to latest firmware because of posts suggesting fake gps no longer works...and I’m not going to test to find out !
My M2z CE has the NLD patch for FCC ,which was added before later firmware updates stopping and preventing rolling back to install the patch,so it’s permanent.
It can reach 7,500 meter with same setup as mini, ( SC..5.8 yagi combo same flight path) before battery limit (and nerve 58%) suggest time to head home.
I feel for those with terrible range regardless of location, my mini was initially poor, and re goggles were pathetic, before being sent back and repaired reluctantly by DJI.
They now go as far as the M2z....
Once the mini especially ,is dialled in properly, it becomes pretty amazing, even though it looks like a toy...friends can’t believe what it can do, when watching video of the flight on a 4k tv.
P.s Study the flight path pre fight, and make sure you have a sunshade/hood for a clear view.
