DucatiWiz
djiuser_RR0XU7lwwBA8 Posted at 2020-9-11 07:34
Ok since we are going off topic ...
-Did anyone manage to hack his drone to FCC mode in Europe ?
I have tried the procedure multiple times and with placing the aircraft indoors with zero GPS satellites but still I get 13 channels in transmission tab not 11 that is very strange
I have this working permanently with the latest DJI Fly app and all latest firmware - however I'm yet to test just how much better it makes things. There is a new hack that works like this:
In the DJI controller, there is a config file in the root of the firmware which tells the controller whether or not to check for the current country. You can use fake GPS to change your country location indoors, then hack this file to set "disable_country=1" and it will never change back as it'll never check your location again. I set my location to Bolivia as that has the most amount of channels available at the highest wattage, it works great, but I'm yet to do a real-world range test.
There are videos of people testing the antenna output with a meter after the hack with poor results, but they don't realise that this won't work because, as with all battery powered wifi tech, there is battery-saving software in the device that only ramps up the power when it's needed, so you'd need to test the drone at max range to get a true reading.
If you want to try, full instructions can be found here. https://mavic-mini-ce-boost.github.io/
A few notes:
1. Set your location to Bolivia as you'll get the most unrestricted channels.
2. I was able to do the hack without downgrading the DJI fly app. The only android I have is a Samsung S7 tab, I just got the latest Fake GPS app, used the Fly app from the Samsung store (1.4) and it all worked fine.
3. The hack is permanent because it hacks the config file, so afterwards, you can switch to an iPhone and it still works fine which is great - just borrow an Android device once if you need to.
4. You'll never get the full 30db on 5.8 that you get from an FCC drone because the CE version has different hardware, but you should get a useful output boost on the 5.8 range (which is less cluttered in the EU) from 14db to 19db, which is reported to make quite a difference.
All before and after range tests welcome!
