m80116
Flight distance : 3264131 ft
One thing I wish is that we could see the signal strengths in -dBm the system is experiencing...
I have a feeling that somehow the reflectors manage to better convey the video feedback, but it might be possible that they don't get you any further. I've never done proper tests... I just noticed that my video was less stuttery with them on, and decided to keep using them.
Then I also think some thin sheet aluminum like that in the prabolics (let alone the home chicken-wrap foil) might work better with a 5.8 GHz wave.
There's more, for what I can see from a video coming from Japan (I've made a screenshot of it, don't have link to share atm), the 2.4 GHz emission has a shady area exactly around the 1400 to 1500 meters at about 80 m height... but since no angle of the antenna polarization was fixed we can't figure out if some shady area above or below the mid point has had an impact, this concerned the trasmission (RC to AC). Then there's feedback (AC to RC), that might have been quite reliably framed as the OP didn't move much, but again... shifting height or side to side could have had a good impact on video feeback signal strength.
It's slipping through my hands this whole argument but hope to have made a good point. I'll test my Y/U 5.8 antennas when they arrive (also... did you know that one antenna sits lower in the enclosure than the other? this might also have an impact as the extender, especially the Y/U is not aligned perfectly). I've also read reports of just one antenna being used in some cases...but don't remember any longer.
