m80116
Flight distance : 3264131 ft
That kind of oil is by nature compatible with metals and softer metals like brass and plastics. Bearings with motion, time, age, humidity, heat cycles give way to dryness, slowly releasing the most volatile part of the grease. Adding a compatible oil in moderate amounts prevents additional volatile runoff and possibly condition the existing grease inside the bearing by slowly seeping in rather tha letting it dry even more.
My Mini was already enjoying this treatment before the lockdown, and was already showing signs of increased resistance before I applied it. As for the dust accumulation it's just a speculation, the external collars were pristine (as you can see in the video) as I also have dust covers, and most of the controlled amount of oil seeps immediately in along the shaft.
