djiuser_5hoSuY0HZd5R
Flight distance : 2043392 ft
Hi, I went and bought a tachometer for checking model aircraft propeller speeds from a hobby shop.
I launched the mini and while in a hover, checked each of the propeller speeds on each motor.
I found that the rear left was running faster than the other motors, the other three motors were within 50 rpm of each other.
I landed and powered down, then checked the rear left props.
There was definitely distortion of the pitch of the blades to flatter than the others.
I then “adjusted” the blades by gently bending them back to match a new blade, then retested in hover flight again, adjusting until speed were close to the other motors.
Flying more stable and quieter. Note that I never had a error message for the motors.
Problem is, what is the correct rpm range for Mavic Mini Motors at hover?
I know there are variables that affect motors speeds, eg. altitude, temperature, payloads, wind, etc.
Does DJI have a table/graph for reference based on a stock standard MM?
