bablefish
Flight distance : 191001 ft
In order to protect your flight safety, we added the detection of abnormal motor speed in the V1.0.5 firmware version.
If such problems occur during flight, it is recommended that you first check whether the propellers are damaged or deformed.
If the deformation is serious or damaged It is recommended that you replace the entire pair of propellers on the corresponding motor first; if there is a slight propellers deformation caused by improper storage, it is recommended that you smooth the corresponding propellers before attempting; if the above operations are not tried multiple times, it is recommended that you send Back to detection processing.
At the same time, it is recommended that you refer to the following legend during daily storage. Pay particular attention to the placement of the propellers of the rear arm to ensure that the propellers are unfolded flush to avoid pressing the propellers during storage.
How should I save it at ordinary times and it will not be easy to deform the propellers?
When storing, try to place the propellers overlapping and parallel. When placing in the storage box, try not to press the protrusions in the middle of the storage box as much as possible. If convenient, you can use the cable tie to store the propellers for storage .
