120ccpm
Flight distance : 1396755 ft
rhain.louis@gmail.com Posted at 6-9 07:57
I also just had the left rear motor issue on a 3 week old MM. I have thew fly more combo so I replaced the props, but when I did the indoor hover test and checked the DAT file my right rear prop was also showing elevated RPMs in the 11-12k range, versus ~9500 RPM for the front props. I've read a bunch of threads on this and I'm unsure how to store the MM in the fly more case to avoid this from happening again- can it be safely stored in the case if the props are facing each other, or are the props getting damaged no matter how it's store in the case? I wasn't as careful with storing the MM in the case earlier, so the rear props may have been deformed by the bottom of the case during storage. I'm worried about that now, so I want to make sure I store it in the case correctly.
If your Right Rear motor is hovering in the 11-12k RPM range, I would replace the props.
DJI responded to a MM owner with some motor specs, where hovering speed was listed at 10200 RPMs, but they didn't say if that's an average value, or if it should be considered an upper limit. In any case, we have seen numbers as low as 9400 RPMs with brand new props, so - in my personal opinion - 11-12k is too high. Replace, do the test again, and see for yourself if that helped or not. |
