HedgeTrimmer
Dronason Posted at 6-26 14:52
Today, flying with my daughter, same MM drone, no flight issue. Then we see that manual mode was not working on her MM, its firmware was not on latest. Done the update and then we get on her that error message. On mine nothing. Check propellers, screws on both, no difference. That day there was some wind. We left them fly at low altitude out of wind with no issue. Then fly again, the same way, same location with no issue, attitude was same, no difference to wind reaction. Sounds really like again an over engineered check with not enough real field testing. So many "warning" messages that disturb pilot with limited real ground apart covering some ass.
Really want to dig into it.
Carefully label props on your MM as to location and on your daughter's MM as to location.
Along with labeling who's props - which drone.
Then swap your MM's props with your daughter MM's props to location as marked.
Fly that way and see if your MM flags an error message about ESC "Motor Speed Error"; with it using her MM's props.
Not to in anyway put your daughter down. After a while, you may see her MM start having ESC "Motor Speed Error" messages. Possible cause being your daughter's MM storage case(s), or how she folds props for storage vs. how you fold your props for storage. |
