Cetacean
Flight distance : 2528264 ft
Aloha fans8c2a,
Yes, as ebxgsxr noted, the 4K camera for the Phantom 3 4K can be mounted on the P3 Advanced to convert the P3 Advanced into a P3 Pro. The P3 4K is a 4K camera on a Phantom body using WIFI as a transmission medium. It is the only Phantom that does not display Live View in 720p. I believe it uses 480p for Live View because of the WIFI.
As ebxgsxr noted, the P3 Advanced uses a camera with 2.7K as the highest resolution. The rest of the platform and remote controller is identical to the P3 Pro. This has been discussed previously on the Forum but DJI recommends that the conversion be made by DJI Support. Because of the legacy nature of these products and if you are a handy DIYer, making the conversion yourself is something worth considering.
If the modification to the P3 Advanced controller is to replace the USB module with the HDMI Module, there should still be no problem. When all the conversions are complete, you will have a P3 Pro with an HDMI module - just like mine!
Hope this helps!
Be safe!
Aloha and Drone On! |
