DJI Thor
Flight distance : 13602 ft
Hi, may I know if you have enabled distance restriction? If so, how long did you set the distance? Please try to disable to distance limitation and try again.
If this is not the case, please try to refresh the latest firmware for the drone via DJI Assistant 2 and check if the app has been updated. If the issue persists, please kindly provide a screen recording video of the issue and provide me with the firmware and mobile device info to check further. Thank you. |
