djiuser_T22nTHCBs69D
I was having all the same issues that everyone here was having. I too have a Note 9, bought new cables, uninstalled, etc. This is what worked for me. First, use a cable shorter than 12 inches. The longer the cable, the more degraded the communication between the devices can be.
Make sure your controller is on first. And you have the connection prompt open so its waiting for the USB device.
Then I plugged my phone into my computer which brought up the notification on my phone that the USB was being used for media and that the phone was controlling the connection. I changed it to usb for file transfers and to let the host control the connection. Don't close the connection dialogue unplug the cable from the pc and put into the top port on the controller and make sure to push it in all the way. Once I did this, it connected immediately. After this itll go thru the connecting to the bird. Then itll update the firmware.. Once done,, you're all set I've! Hope this helps, happy flying! |
