fansdc11b173
With the flight pack in a large quad running 12S and utilising ESC Telemetry, I note that Betaflight reads in the voltage from each ESC and then averages them, however the reading is 25.5V even though I have 12S (50V) connected. However Betaflight also reports the battery voltage summary as correct, 50V which is normally used by betaflight FC for OSD. When using DJI Air Unit it seems to be picking up the averaged votlage which in Betaflight is incorrect. So two bugs here in my view, Betaflight ESC Telemetry with anything over 25,5V and DJI OSD telemetry using this voltage. Anyway, I wonder if someone could look into this issue, 12S is getting popular in bigger quads and smaller ones, but using it with DJI FPV you can't relaibly get the goggles to display the pack voltage, it's just stuck at 25.5V, my assumption is the 8 bit limit, 0.1 x 255 (8bit) and getting max reading of 25.5V.
Any assistance in getting this reviewed would be appreciated, or a fix for it. I am using a iFlight Succex-D F7 Standard flight controller powered from a 12V BEC, all works well except for this voltage OSD issue.
Goggle View
