ThalisGr
Based on various reviews and opinions I decided to buy the Skyreat filters from Amazon UK, when they became available. They are the ND/PL version as they were the only available at the moment.
I got them last week but I tried them just today morning with some good sunny weather.
First of all I have to say tha despite what I was told, the Mini with the filter on, weights 250gr, which in theory makes the fly illegal without registration. But I would say that if you 'bend' the rules a bit then it is probably fine. Now the Skyreat filters are not the most expensive ones, neither the cheapest. I bought them £54, which is an average price and I think their quality is great. For such small thing the precision and attention to detail is awesome.
Now my background is of an enthousiastic photographer who only occasionally shoots video. Shooting photos with DSLR and ND filters is quite straight forward, especially if you have a graduated filter and a good camera. Shooting video with a ND filter can be tricky, especially if you want to stick to famous video rule, where the best results come if your shutter speed is double your frame rate or so. You need to plan ahead and have the experience to use the right ND filter. This is especially important when you shoot with the drone where is not so easy to change filters.
So today I shot with ND8, ND16 and ND32. The last one could be only used when most of the frame was sky...any other time the video was underexposure. ND16 was good for sky and ground especially from quite a height, while ND8 was the best option when I flew low and had lots of ground and trees on my frame.
As I said I am not the most experience videographer so I had to take off and on in order to change filters 4 times :-).
Finally a small detail...I started my fly with ND16, then 8, then 32, then 16, and finally 8 again. When I came back home and saw the first footage I was disappointed, as the vignette was clearly visible in the bottom corners . But then any other footage was without any visible vignette (see the comparison screenshots). Then I recalled that the first filter went on without me wearring my glasses. So my advise is to be careful when you use the filters because they need to be installed properly and be in perfect align with the camera lens.
