ICDroneSE
Flight distance : 622575 ft
DJI Gamora Posted at 5-12 20:31
Hi, there.
Did you mean controller charge phone when you said ‘Does the DJI Fly app have a setting where you can set if the controller charged your controller ’ ?
The remote controller automatically charges Android devices. For iOS devices, please first make sure that charging is enabled in DJI Fly. Because it is closed by default. It needs to be enabled each time the remote controller is powered on. Please refer to the following pictures about the setting method. You can also check the User Manual about that too. https://dl.djicdn.com/downloads/Mavic_Air_2/20200511/Mavic_Air_2_User_Manual_v1.0_en.pdf
Oh I see. I use an android device, so I guess I don't get that option. Thanks! |
