Labroides
Flight distance : 9991457 ft
SuperiorDroneNC Posted at 5-13 16:00
Thank you so much for your reply. This is a big help. Will I need to rename them files after putting them into a folder or can I download them as they are from the folder?
If you put two files with the same name in the same folder, the computer will want you to rename one, or it will overwrite.
Keep them in separate folders and it's all OK
Do you realise that you can go into the camera settings and have teh camera continue flie naming from where the last flight finished rather than resetting to 001 each flight?
Look for File Index Mode and change it to continuous rather than reset. |
