Milhouse1234
Denmark
The "Advanced Sensing is Enabled on M210" does not prompt when I roslaunch. Here's the full logs
Compiled log:
lucas@lucas-Lenovo:~/catkin_ws$ rm -rf build
lucas@lucas-Lenovo:~/catkin_ws$ catkin_make
Base path: /home/lucas/catkin_ws
Source space: /home/lucas/catkin_ws/src
Build space: /home/lucas/catkin_ws/build
Devel space: /home/lucas/catkin_ws/devel
Install space: /home/lucas/catkin_ws/install
#### Running command: "cmake /home/lucas/catkin_ws/src -DCATKIN_DEVEL_PREFIX=/home/lucas/catkin_ws/devel -DCMAKE_INSTALL_PREFIX=/home/lucas/catkin_ws/install -G Unix Makefiles" in "/home/lucas/catkin_ws/build"
-- The C compiler identification is GNU 5.4.0
-- The CXX compiler identification is GNU 5.4.0
-- Check for working C compiler: /usr/bin/cc
-- Check for working C compiler: /usr/bin/cc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Using CATKIN_DEVEL_PREFIX: /home/lucas/catkin_ws/devel
-- Using CMAKE_PREFIX_PATH: /home/lucas/catkin_ws/devel;/opt/ros/kinetic
-- This workspace overlays: /home/lucas/catkin_ws/devel;/opt/ros/kinetic
-- Found PythonInterp: /usr/bin/python2 (found suitable version "2.7.12", minimum required is "2")
-- Using PYTHON_EXECUTABLE: /usr/bin/python2
-- Using Debian Python package layout
-- Using empy: /usr/bin/empy
-- Using CATKIN_ENABLE_TESTING: ON
-- Call enable_testing()
-- Using CATKIN_TEST_RESULTS_DIR: /home/lucas/catkin_ws/build/test_results
-- Found gtest sources under '/usr/src/gmock': gtests will be built
-- Found gmock sources under '/usr/src/gmock': gmock will be built
-- Found PythonInterp: /usr/bin/python2 (found version "2.7.12")
-- Looking for pthread.h
-- Looking for pthread.h - found
-- Looking for pthread_create
-- Looking for pthread_create - not found
-- Looking for pthread_create in pthreads
-- Looking for pthread_create in pthreads - not found
-- Looking for pthread_create in pthread - found
-- Found Threads: TRUE
-- Using Python nosetests: /usr/bin/nosetests-2.7
-- catkin 0.7.20
-- BUILD_SHARED_LIBS is on
-- ~~ traversing 3 packages in topological order:
-- ~~ - beginner_tutorials
-- ~~ - dji_sdk
-- ~~ - dji_sdk_demo
-- +++ processing catkin package: 'beginner_tutorials'
-- ==> add_subdirectory(beginner_tutorials)
-- Using these message generators: gencpp;geneus;genlisp;gennodejs;genpy
-- beginner_tutorials: 1 messages, 1 services
-- +++ processing catkin package: 'dji_sdk'
-- ==> add_subdirectory(Onboard-SDK-ROS/dji_sdk)
-- Using Finddjiosdk-core.cmake find djiosdk-core
-- Found djiosdk-core:
-- - Includes: /usr/local/include
-- - Libraries: /usr/local/lib/libdjiosdk-core.a
-- dji_sdk: 13 messages, 28 services
-- +++ processing catkin package: 'dji_sdk_demo'
-- ==> add_subdirectory(Onboard-SDK-ROS/dji_sdk_demo)
-- Found OpenCV 3.3.1 installed in the system, will use it for depth perception sample
-- - Includes: /opt/ros/kinetic/include/opencv-3.3.1-dev;/opt/ros/kinetic/include/opencv-3.3.1-dev/opencv
-- Did not find viz3d in OpenCV
-- Found 10.2 CUDA installed in the system, will use it for depth perception sample
-- - Includes: /usr/local/cuda/include
-- Configuring done
-- Generating done
-- Build files have been written to: /home/lucas/catkin_ws/build
#### Running command: "make -j12 -l12" in "/home/lucas/catkin_ws/build"
Scanning dependencies of target _beginner_tutorials_generate_messages_check_deps_AddTwoInts
Scanning dependencies of target std_msgs_generate_messages_eus
Scanning dependencies of target _beginner_tutorials_generate_messages_check_deps_Num
Scanning dependencies of target std_msgs_generate_messages_lisp
Scanning dependencies of target std_msgs_generate_messages_py
Scanning dependencies of target std_msgs_generate_messages_nodejs
Scanning dependencies of target std_msgs_generate_messages_cpp
Scanning dependencies of target _dji_sdk_generate_messages_check_deps_MissionWpUpload
Scanning dependencies of target _dji_sdk_generate_messages_check_deps_GPSUTC
Scanning dependencies of target _dji_sdk_generate_messages_check_deps_MissionHpUpdateRadius
Scanning dependencies of target _dji_sdk_generate_messages_check_deps_MissionWpSetSpeed
Scanning dependencies of target _dji_sdk_generate_messages_check_deps_MissionStatus
[ 0%] Built target std_msgs_generate_messages_cpp
[ 0%] Built target std_msgs_generate_messages_lisp
[ 0%] Built target std_msgs_generate_messages_nodejs
[ 0%] Built target std_msgs_generate_messages_eus
[ 0%] Built target std_msgs_generate_messages_py
Scanning dependencies of target _dji_sdk_generate_messages_check_deps_MissionWpGetInfo
Scanning dependencies of target _dji_sdk_generate_messages_check_deps_MissionHpUpload
Scanning dependencies of target _dji_sdk_generate_messages_check_deps_DroneArmControl
Scanning dependencies of target _dji_sdk_generate_messages_check_deps_MissionHpAction
Scanning dependencies of target _dji_sdk_generate_messages_check_deps_DroneTaskControl
[ 0%] Built target _dji_sdk_generate_messages_check_deps_MissionWpSetSpeed
[ 0%] Built target _beginner_tutorials_generate_messages_check_deps_AddTwoInts
[ 0%] Built target _dji_sdk_generate_messages_check_deps_GPSUTC
[ 0%] Built target _beginner_tutorials_generate_messages_check_deps_Num
[ 0%] Built target _dji_sdk_generate_messages_check_deps_MissionHpUpdateRadius
[ 0%] Built target _dji_sdk_generate_messages_check_deps_MissionStatus
[ 0%] Built target _dji_sdk_generate_messages_check_deps_MissionWpUpload
Scanning dependencies of target _dji_sdk_generate_messages_check_deps_CameraAction
Scanning dependencies of target _dji_sdk_generate_messages_check_deps_MobileData
Scanning dependencies of target sensor_msgs_generate_messages_nodejs
Scanning dependencies of target _dji_sdk_generate_messages_check_deps_MissionWaypoint
Scanning dependencies of target _dji_sdk_generate_messages_check_deps_FlightAnomaly
Scanning dependencies of target _dji_sdk_generate_messages_check_deps_MissionWaypointAction
Scanning dependencies of target _dji_sdk_generate_messages_check_deps_VOPosition
[ 0%] Built target _dji_sdk_generate_messages_check_deps_MissionHpUpload
[ 0%] Built target _dji_sdk_generate_messages_check_deps_DroneArmControl
[ 0%] Built target _dji_sdk_generate_messages_check_deps_MissionWpGetInfo
[ 0%] Built target _dji_sdk_generate_messages_check_deps_DroneTaskControl
[ 0%] Built target sensor_msgs_generate_messages_nodejs
[ 0%] Built target _dji_sdk_generate_messages_check_deps_MissionHpAction
Scanning dependencies of target geometry_msgs_generate_messages_nodejs
Scanning dependencies of target _dji_sdk_generate_messages_check_deps_FCTimeInUTC
Scanning dependencies of target _dji_sdk_generate_messages_check_deps_SetLocalPosRef
Scanning dependencies of target _dji_sdk_generate_messages_check_deps_StereoVGASubscription
Scanning dependencies of target _dji_sdk_generate_messages_check_deps_SetHardSync
Scanning dependencies of target nav_msgs_generate_messages_nodejs
[ 0%] Built target geometry_msgs_generate_messages_nodejs
[ 0%] Built target nav_msgs_generate_messages_nodejs
Scanning dependencies of target _dji_sdk_generate_messages_check_deps_QueryDroneVersion
[ 0%] Built target _dji_sdk_generate_messages_check_deps_MobileData
[ 0%] Built target _dji_sdk_generate_messages_check_deps_MissionWaypoint
[ 0%] Built target _dji_sdk_generate_messages_check_deps_CameraAction
[ 0%] Built target _dji_sdk_generate_messages_check_deps_FlightAnomaly
[ 0%] Built target _dji_sdk_generate_messages_check_deps_VOPosition
[ 0%] Built target _dji_sdk_generate_messages_check_deps_MissionWaypointAction
Scanning dependencies of target _dji_sdk_generate_messages_check_deps_SendMobileData
Scanning dependencies of target _dji_sdk_generate_messages_check_deps_MissionHpResetYaw
Scanning dependencies of target _dji_sdk_generate_messages_check_deps_MissionHpGetInfo
Scanning dependencies of target _dji_sdk_generate_messages_check_deps_Activation
[ 0%] Built target _dji_sdk_generate_messages_check_deps_SetLocalPosRef
Scanning dependencies of target _dji_sdk_generate_messages_check_deps_SDKControlAuthority
Scanning dependencies of target _dji_sdk_generate_messages_check_deps_WaypointList
Scanning dependencies of target _dji_sdk_generate_messages_check_deps_MissionWpGetSpeed
[ 0%] Built target _dji_sdk_generate_messages_check_deps_StereoVGASubscription
[ 0%] Built target _dji_sdk_generate_messages_check_deps_FCTimeInUTC
Scanning dependencies of target _dji_sdk_generate_messages_check_deps_MFIOConfig
[ 0%] Built target _dji_sdk_generate_messages_check_deps_SetHardSync
Scanning dependencies of target _dji_sdk_generate_messages_check_deps_StereoDepthSubscription
Scanning dependencies of target _dji_sdk_generate_messages_check_deps_SetupCameraStream
Scanning dependencies of target _dji_sdk_generate_messages_check_deps_MFIOSetValue
[ 0%] Built target _dji_sdk_generate_messages_check_deps_QueryDroneVersion
[ 0%] Built target _dji_sdk_generate_messages_check_deps_MissionHpResetYaw
Scanning dependencies of target _dji_sdk_generate_messages_check_deps_Gimbal
[ 0%] Built target _dji_sdk_generate_messages_check_deps_MissionHpGetInfo
[ 0%] Built target _dji_sdk_generate_messages_check_deps_Activation
[ 0%] Built target _dji_sdk_generate_messages_check_deps_SendMobileData
[ 0%] Built target _dji_sdk_generate_messages_check_deps_MFIOConfig
[ 0%] Built target _dji_sdk_generate_messages_check_deps_SDKControlAuthority
[ 0%] Built target _dji_sdk_generate_messages_check_deps_MissionWpGetSpeed
Scanning dependencies of target _dji_sdk_generate_messages_check_deps_MissionWpAction
Scanning dependencies of target _dji_sdk_generate_messages_check_deps_SendPayloadData
[ 0%] Built target _dji_sdk_generate_messages_check_deps_WaypointList
Scanning dependencies of target _dji_sdk_generate_messages_check_deps_PayloadData
[ 0%] Built target _dji_sdk_generate_messages_check_deps_SetupCameraStream
[ 0%] Built target _dji_sdk_generate_messages_check_deps_StereoDepthSubscription
Scanning dependencies of target _dji_sdk_generate_messages_check_deps_Stereo240pSubscription
Scanning dependencies of target _dji_sdk_generate_messages_check_deps_MissionWaypointTask
Scanning dependencies of target _dji_sdk_generate_messages_check_deps_MissionHotpointTask
Scanning dependencies of target _dji_sdk_generate_messages_check_deps_MissionHpUpdateYawRate
Scanning dependencies of target geometry_msgs_generate_messages_py
Scanning dependencies of target sensor_msgs_generate_messages_py
[ 0%] Built target _dji_sdk_generate_messages_check_deps_MFIOSetValue
[ 0%] Built target _dji_sdk_generate_messages_check_deps_Gimbal
[ 0%] Built target sensor_msgs_generate_messages_py
[ 0%] Built target geometry_msgs_generate_messages_py
Scanning dependencies of target sensor_msgs_generate_messages_lisp
Scanning dependencies of target nav_msgs_generate_messages_py
[ 0%] Built target _dji_sdk_generate_messages_check_deps_MissionWpAction
Scanning dependencies of target nav_msgs_generate_messages_lisp
Scanning dependencies of target geometry_msgs_generate_messages_lisp
[ 0%] Built target sensor_msgs_generate_messages_lisp
[ 0%] Built target nav_msgs_generate_messages_py
[ 0%] Built target _dji_sdk_generate_messages_check_deps_SendPayloadData
Scanning dependencies of target sensor_msgs_generate_messages_eus
[ 0%] Built target nav_msgs_generate_messages_lisp
[ 0%] Built target _dji_sdk_generate_messages_check_deps_PayloadData
[ 0%] Built target _dji_sdk_generate_messages_check_deps_MissionWaypointTask
[ 0%] Built target _dji_sdk_generate_messages_check_deps_Stereo240pSubscription
Scanning dependencies of target geometry_msgs_generate_messages_eus
[ 0%] Built target _dji_sdk_generate_messages_check_deps_MissionHotpointTask
Scanning dependencies of target geometry_msgs_generate_messages_cpp
[ 0%] Built target geometry_msgs_generate_messages_lisp
[ 0%] Built target sensor_msgs_generate_messages_eus
Scanning dependencies of target nav_msgs_generate_messages_eus
Scanning dependencies of target nav_msgs_generate_messages_cpp
Scanning dependencies of target beginner_tutorials_generate_messages_eus
Scanning dependencies of target sensor_msgs_generate_messages_cpp
[ 0%] Built target _dji_sdk_generate_messages_check_deps_MissionHpUpdateYawRate
Scanning dependencies of target beginner_tutorials_generate_messages_lisp
Scanning dependencies of target beginner_tutorials_generate_messages_py
Scanning dependencies of target beginner_tutorials_generate_messages_nodejs
[ 0%] Built target geometry_msgs_generate_messages_eus
[ 0%] Built target geometry_msgs_generate_messages_cpp
Scanning dependencies of target beginner_tutorials_generate_messages_cpp
[ 0%] Built target nav_msgs_generate_messages_eus
[ 0%] Built target nav_msgs_generate_messages_cpp
[ 1%] Built target beginner_tutorials_generate_messages_eus
[ 1%] Built target sensor_msgs_generate_messages_cpp
Scanning dependencies of target dji_sdk_generate_messages_nodejs
[ 3%] Built target beginner_tutorials_generate_messages_py
[ 4%] Built target beginner_tutorials_generate_messages_lisp
Scanning dependencies of target dji_sdk_generate_messages_py
[ 5%] Built target beginner_tutorials_generate_messages_nodejs
Scanning dependencies of target dji_sdk_generate_messages_lisp
[ 5%] Built target beginner_tutorials_generate_messages_cpp
Scanning dependencies of target dji_sdk_generate_messages_eus
[ 21%] Built target dji_sdk_generate_messages_nodejs
Scanning dependencies of target dji_sdk_generate_messages_cpp
[ 38%] Built target dji_sdk_generate_messages_py
[ 55%] Built target dji_sdk_generate_messages_lisp
[ 72%] Built target dji_sdk_generate_messages_eus
[ 89%] Built target dji_sdk_generate_messages_cpp
[ 89%] Built target beginner_tutorials_generate_messages
Scanning dependencies of target demo_local_position_control
Scanning dependencies of target demo_payload_comm
Scanning dependencies of target demo_time_sync
Scanning dependencies of target demo_mfio
Scanning dependencies of target demo_flight_control
Scanning dependencies of target dji_sdk_node
Scanning dependencies of target demo_mission
Scanning dependencies of target demo_camera_gimbal
Scanning dependencies of target demo_mobile_comm
[ 90%] Building CXX object Onboard-SDK-ROS/dji_sdk_demo/CMakeFiles/demo_payload_comm.dir/src/demo_payload_comm.cpp.o
[ 90%] Building CXX object Onboard-SDK-ROS/dji_sdk_demo/CMakeFiles/demo_local_position_control.dir/src/demo_local_position_control.cpp.o
[ 90%] Building CXX object Onboard-SDK-ROS/dji_sdk_demo/CMakeFiles/demo_mfio.dir/src/demo_mfio.cpp.o
[ 90%] Building CXX object Onboard-SDK-ROS/dji_sdk_demo/CMakeFiles/demo_time_sync.dir/src/demo_time_sync.cpp.o
[ 90%] Building CXX object Onboard-SDK-ROS/dji_sdk_demo/CMakeFiles/demo_mission.dir/src/demo_mission.cpp.o
[ 90%] Building CXX object Onboard-SDK-ROS/dji_sdk_demo/CMakeFiles/demo_camera_gimbal.dir/src/demo_camera_gimbal.cpp.o
[ 91%] Building CXX object Onboard-SDK-ROS/dji_sdk_demo/CMakeFiles/demo_flight_control.dir/src/demo_flight_control.cpp.o
[ 92%] Building CXX object Onboard-SDK-ROS/dji_sdk_demo/CMakeFiles/demo_mobile_comm.dir/src/demo_mobile_comm.cpp.o
[ 92%] Building CXX object Onboard-SDK-ROS/dji_sdk/CMakeFiles/dji_sdk_node.dir/src/main.cpp.o
[ 92%] Building CXX object Onboard-SDK-ROS/dji_sdk/CMakeFiles/dji_sdk_node.dir/src/modules/dji_sdk_node_services.cpp.o
[ 93%] Building CXX object Onboard-SDK-ROS/dji_sdk/CMakeFiles/dji_sdk_node.dir/src/modules/dji_sdk_node.cpp.o
[ 94%] Building CXX object Onboard-SDK-ROS/dji_sdk/CMakeFiles/dji_sdk_node.dir/src/modules/dji_sdk_node_control.cpp.o
[ 95%] Linking CXX executable /home/lucas/catkin_ws/devel/lib/dji_sdk_demo/demo_mfio
[ 95%] Built target demo_mfio
[ 95%] Building CXX object Onboard-SDK-ROS/dji_sdk/CMakeFiles/dji_sdk_node.dir/src/modules/dji_sdk_node_mission_services.cpp.o
[ 95%] Linking CXX executable /home/lucas/catkin_ws/devel/lib/dji_sdk_demo/demo_camera_gimbal
[ 95%] Linking CXX executable /home/lucas/catkin_ws/devel/lib/dji_sdk_demo/demo_payload_comm
[ 95%] Built target demo_payload_comm
[ 95%] Building CXX object Onboard-SDK-ROS/dji_sdk/CMakeFiles/dji_sdk_node.dir/src/modules/dji_sdk_node_subscriber.cpp.o
[ 95%] Built target demo_camera_gimbal
[ 96%] Building CXX object Onboard-SDK-ROS/dji_sdk/CMakeFiles/dji_sdk_node.dir/src/modules/dji_sdk_node_publisher.cpp.o
[ 97%] Linking CXX executable /home/lucas/catkin_ws/devel/lib/dji_sdk_demo/demo_time_sync
[ 98%] Linking CXX executable /home/lucas/catkin_ws/devel/lib/dji_sdk_demo/demo_local_position_control
[ 98%] Linking CXX executable /home/lucas/catkin_ws/devel/lib/dji_sdk_demo/demo_mission
[ 98%] Built target demo_time_sync
[ 98%] Building CXX object Onboard-SDK-ROS/dji_sdk/CMakeFiles/dji_sdk_node.dir/src/modules/dji_sdk_node_mobile_comm.cpp.o
[ 98%] Building CXX object Onboard-SDK-ROS/dji_sdk/CMakeFiles/dji_sdk_node.dir/src/modules/dji_sdk_node_payload_comm.cpp.o
[ 98%] Built target demo_local_position_control
[ 98%] Built target demo_mission
[100%] Building CXX object Onboard-SDK-ROS/dji_sdk/CMakeFiles/dji_sdk_node.dir/src/modules/dji_sdk_node_time_sync.cpp.o
[100%] Linking CXX executable /home/lucas/catkin_ws/devel/lib/dji_sdk_demo/demo_flight_control
[100%] Built target demo_flight_control
[100%] Linking CXX executable /home/lucas/catkin_ws/devel/lib/dji_sdk_demo/demo_mobile_comm
[100%] Built target demo_mobile_comm
[100%] Linking CXX executable /home/lucas/catkin_ws/devel/lib/dji_sdk/dji_sdk_node
[100%] Built target dji_sdk_node
And roslaunch log:
lucas@lucas-Lenovo:~/catkin_ws$ roslaunch dji_sdk sdk.launch
... logging to /home/lucas/.ros/log/bfb50338-99a6-11ea-99cd-3c950953954d/roslaunch-lucas-Lenovo-12776.log
Checking log directory for disk usage. This may take awhile.
Press Ctrl-C to interrupt
Done checking log file disk usage. Usage is <1GB.
started roslaunch server http://lucas-Lenovo:39493/
SUMMARY
PARAMETERS
* /dji_sdk/align_time: False
* /dji_sdk/app_id: 1087420
* /dji_sdk/app_version: 1
* /dji_sdk/baud_rate: 1000000
* /dji_sdk/enc_key: 7e7fed6c7b14df965...
* /dji_sdk/serial_name: /dev/ttyUSB0
* /dji_sdk/use_broadcast: False
* /rosdistro: kinetic
* /rosversion: 1.12.14
NODES
dji_sdk (dji_sdk/dji_sdk_node)
auto-starting new master
process[master]: started with pid [12786]
ROS_MASTER_URI=http://localhost:11311
setting /run_id to bfb50338-99a6-11ea-99cd-3c950953954d
process[rosout-1]: started with pid [12799]
started core service [/rosout]
process[dji_sdk-2]: started with pid [12816]
STATUS/1 @ init, L56: Attempting to open device /dev/ttyUSB0 with baudrate 1000000...
STATUS/1 @ init, L66: ...Serial started successfully.
STATUS/1 @ parseDroneVersionInfo, L762: Device Serial No. = ****************
STATUS/1 @ parseDroneVersionInfo, L764: Hardware = PM420
STATUS/1 @ parseDroneVersionInfo, L765: Firmware = 3.4.3.37
ERRORLOG/1 @ initVirtualRC, L1188: Virtual RC is not supported on this platform!
STATUS/1 @ activate, L1398: version 0x3040325
STATUS/1 @ activate, L1411: Activation successful
STATUS/1 @ verify, L247: Verify subscription successful.
STATUS/1 @ initGimbal, L926: Checking if gimbal is connected ...
STATUS/1 @ startPackage, L353: Start package 0 result: 0.
STATUS/1 @ startPackage, L355: Package 0 info: freq=50, nTopics=1.
STATUS/1 @ removePackage, L471: Remove package 0 successful.[ INFO] [1589875211.690206230]: drone activated
[ INFO] [1589875211.786229726]: Use data subscription to get telemetry data!
[ INFO] [1589875211.786250019]: align_time_with_FC set to false. We will use ros time to time stamp messages!
STATUS/1 @ startPackage, L353: Start package 2 result: 0.
STATUS/1 @ startPackage, L355: Package 2 info: freq=100, nTopics=3.
STATUS/1 @ startPackage, L353: Start package 1 result: 0.
STATUS/1 @ startPackage, L355: Package 1 info: freq=50, nTopics=13.
STATUS/1 @ startPackage, L355: Package 0 info: freq=5, nTopics=6.
STATUS/1 @ startPackage, L353: Start package 3 result: 0.
STATUS/1 @ startPackage, L355: Package 3 info: freq=400, nTopics=1.
At this point I'm assuming I messed up when trying to setup the advanced sensing, but i've done it twice by now and installed all the dependencies (LibUSb, FFmpeg and OpenCV, including an ACM driver) and the udev file is good to go:
My system is x86 so it should support advanced sensing.
Any suggestion? |
