NordicOsmoMan
Norway
Matman Posted at 5-15 16:15
No, I’m using the same setup as you and haven’t seen this before, maybe remove and reinstall LumaFusion? I export to 4K (same settings except I use h.265, 24fps) using extreme video quality.
Ok, good it works for you. in what format do you record your clips in DJI Osmo Action? mp4 or MOV.
Ive heard other also having the same problem with editing DJI clips in LumaFusion or IOS.
Lumatech says its how IOS interpret the mp4 file, and one solution is to reconvert your mp4 file using a program called Handbrake with some specific settings, getting more I-frames or something into the clip.
So Apple might fix this problem in a future upgrade to IOS, but who knows when that will happen.
I started with exporting the film from LumaFusion using the H265 format, so that did not work for me. I have optimized and consolidated the footage and restarted the ipad to no avail. Havent tried installing and reinstalling LumaFusion, but since this is an IOS problem supposedly that might not work.
