Mavic AIR 2 loud fan noise
6603 15 2020-5-17
NightWolf
Flight distance : 398560 ft
Hey guys,
Just unpacked my Mavic air 2 and found a strange and annoying super loud fan noise at idle:
Tried to reset it with DJI assistant 2, switching batteries and powering it off and on several times.
Shall I return?
2020-5-17
Ben Lambert
I think that's normal
2020-5-17
jonny007
Isn't it normal that the fan blows harder when it is idle? You need more cooling than during the flight.
2020-5-17
hallmark007
Flight distance : 9827923 ft
Does it drop down in sound volume after a minute or so? Also in order to know how it actually sounds hold mic about two foot away .
2020-5-17
NightWolf
Not sure, the thing is sitting there doing nothing and the fan is super loud. Do other mavic air 2 owners have a similar issue?
2020-5-17
NightWolf
hallmark007 Posted at 5-17 01:15
It stays loud till battery is depleted, no drop whatsoever. My phone is not great at picking up far away noise so that why I recorded close, but I can assure I can hear the loud noise while I am in another room.
2020-5-17
djiuser_ZutghNDTLB2U
Flight distance : 235768 ft
Mine does the same. I'm not concerned about that to be honest.
2020-5-17
hallmark007
NightWolf Posted at 5-17 01:16
Well fan is supposed to work similar but once cooled down it should get quieter and then kick in again.
2020-5-17
tomaspolo
Israel
Mine sound similar. Does not bother me.
2020-5-17
Hi NightWolf, the fans sound normal. It spins once power on, when the temperature of the main board arrives 60°, the spin speed would be 80%, 100% when the temperature arrives 85° and above.
2020-5-17
Montfrooij
Flight distance : 2560453 ft
It is normal (at least, I was worried first with my MP but it still flies)
2020-5-18
Skraeling
Flight distance : 121407 ft
jonny007 Posted at 5-17 01:08
pretty much this.
you have no airflow from the props sitting still.
2020-5-18
Stoney.
Flight distance : 1439265 ft
Mine did that a lot the first few times that I flew it, now it doesn't do blow as loud or as long as it used to so it should be fine.
2020-5-18
Savage3006
Flight distance : 156709 ft
It's normal go fly and have fun, mine sounds the same.
2020-5-18
keyboardpilot
Flight distance : 781299 ft
Absolutely normal
2020-5-18
djiuser_c7rx1E2ZKBB7
Jamaica
I was curious to know the same thing as I also have noticed this with my MA2. It apparently is normal - I have had no issues nor temperature warnings to indicate a problem and the drone flies/operates quite fine.
2020-7-14
