m80116
Flight distance : 3264131 ft
I highly suggest you take some minutes of your time reading the manual, reading this forum, then have a general inspection. Always remember to check the wind forecast before flying, never ignore wind warnings.
Check the arms for play (fronts should be a bit more flexible but not too much), clean the lens, blow compressed air into every motor and into the gimbal sides and up in the circular rotating bearing. You may also want to lubricate the motor bearings with a little bit of silicone oil from the external spindle (no prop unmount is required). then have a props inspection. The best way is pin them flat on a table and compared them against a new set, otherwise several others are inspecting them mounted.
For the mounted props inspection I suggest you see this post If you want to unmount the props or lubricate see this post (video)
