ESC status error / phantom 3 advanced
32939 453 2020-5-20
CamiloMty
Flight distance : 2117995 ft
Mexico
DJI Susan Posted at 3-9 05:00
Hi there, the beta firmware had been forwarded in PM for users who had mentioned the drone model in the comment. Please let me know if you have not received it. Thank you.
Same problem here. Phantom 3 Pro. Zero problems on last flight time ago, but now I can’t
Can You send me the firmware or the link for download it please?
2022-3-19
DJI Susan
CamiloMty Posted at 3-19 14:52
Hi, I had sent the link to you via PM, please check it out.
2022-3-20
DJI Susan
djiuser_1Fl2Z9oyajis Posted at 3-13 17:35
Hello, I am having the same issue "Esc status error" on my Dji phantom 3 advanced can i get the solution pls.
Thank you
Hi, I had sent you the link via PM, please check.
2022-3-20
DJI Susan
jd62 Posted at 3-18 13:03
Hi Natalia
I  am having the same issue. How do I get a hold of the firmware update to fix this issue? can you please help
Hi, could you please tell me the model of your drone and the operation before the error existed for further confirmation?
2022-3-20
DJI Susan
quiquedrone Posted at 3-19 03:41
Hola, tengo el mismo problema "Error de estado de Esc" en mi Dji phantom 3 advanced, ¿puedo obtener el firmware para corregirlo? Gracias
Hi there, link sent via PM, please check.
2022-3-20
Mongolia
Hello DJI Susan, I am having the same issue "Esc status error" on my Dji phantom 3 advanced can i get the solution pls.
Thank you
2022-3-20
FGNL
DJI Susan Posted at 3-9 04:55
Hi Paul, please tell me the drone model you have for better assistance.
I've got a DJI Phantom 3 Professional
2022-3-21
jd62
Flight distance : 13488 ft
DJI Susan Posted at 3-20 02:26
Hi Susan i have same issue with Phantom 3 advance can i please get an update thanks
2022-3-21
jd62
2022-3-21
jd62
DJI Susan Posted at 3-20 02:28
Hi its a Phantom 3 Advanced showing an ESC error says to turn off and start over contact DJI if continues, it still continues
2022-3-21
DJI Susan
FGNL Posted at 3-21 04:12
Hi there, thank you for getting back, I have sent the link through PM.
2022-3-23
DJI Susan
jd62 Posted at 3-21 17:20
Hi there, I had sent you the link to the beta firmware via PM, you may try to use the firmware and see if that solves your problem. If not, you may need to send the drone back.
2022-3-23
DJI Susan
djiuser_1Fl2Z9oyajis Posted at 3-20 03:20
Thank you
Hi, I had sent the link to you through PM, you may need a computer version to use the PM (private message) feature, you may also need to use the computer to move the firmware file to the drone. Please check it out.
2022-3-23
Mongolia
Thank you
2022-3-23
djiuser_ZB0QCBvzENG1
Can someone help me I have the same issue
2022-3-24
Christopher Nuzum
2022-3-24
Booka
Hello DJI Susan,
I am having the same issue "Esc status error" on my DJI phantom 3 professional, can I get the solution pls?  Mine came after a firmware update to the drone and the RC.  Both were successful and I had a few other issues but was able to work thru all of the others but this one.
Thank you
2022-3-25
djiuser_mBJ7cZMwqibZ
Cyprus
Hi DJI Susan,
Thanks
2022-3-26
Booka
Booka Posted at 3-25 05:43
Hello DJI Susan,
I addressed this to Susan but is there anyone hat can help?
2022-3-28
DJI Gamora
Hello DJI Susan,
Hi, Booka. I had sent the link to you through PM, you may need a computer version to use the PM (private message) feature, you may also need to use the computer to move the firmware file to the drone. Please check it out.
2022-3-29
DJI Gamora
djiuser_mBJ7cZMwqibZ Posted at 3-26 23:52
Hi DJI Susan,
Hi, there. Sorry for the late reply. I have sent the link to you via PM. Please check it.
2022-3-29
captainpaul
I am having same problem, it flew last week
2022-3-30
captainpaul
USSpectre1 Posted at 2021-6-5 12:47
Hello, I have a Phantom 3 Advanced that is also throwing the ECS error when trying to start the engines. Can I get the new Firmware as well?
I have the same problem, it flew last week. now all I get is error message when I try to start propsI also do not get message relative to nearby air fields
2022-3-30
fansde9dacf1
Sorry to jump on an old thread but same issue here - ESC error message after first switch on for several months. Firmware 1.11.20, Phantom 3 Pro. Very grateful for any help please.
2022-4-5
jd62
jd62 Posted at 3-21 17:15
Hi Susan thanks for sending through the dropbox firmware update, i have loaded onto memory card and put into drone and then turned drone on but finding it wont load or update drone is there any instructions on how to update from the dropbox, thanks
2022-4-12
jd62
Has anyone had any success with the updated firmware V01.11.0030 to fix the ESC error, I have downloaded the link but cant get it to load onto drone, wont read it off the card
2022-4-13
djiuser_Zxd6kToNRKEn
DJI Natalia Posted at 2020-5-25 02:51
Hi there, I have sent you a PM, kindly please check it, thanks.
Can you send me the link also thank you?
2022-4-16
djiuser_R3LniQkCiWtC
Flight distance : 1003615 ft
I need this same download please
2022-4-17
I am in need of this same firmware fix ? Please a link for it ?
2022-4-17
DJI Natalia
djiuser_R3LniQkCiWtC Posted at 4-17 15:51
Hi there, I have sent you a PM, please check it. Thanks.
2022-4-18
DJI Natalia
djiuser_Zxd6kToNRKEn Posted at 4-16 09:44
2022-4-18
djiuser_5df5MPcfTE7T
Latvia
Hello! Would it be possible for me to get this firmware as well, please?
2022-4-24
fans458fb4b0
Poland
Hi, I'm having the same problem: ESC error on Phantom 3 pro.
I flyed yesterday without any problem.
What can I do?
Thanks in advance
2022-4-25
DJI Natalia
2022-4-25
ellenton p3a
Why don’t they just post the 1.1 1.30 firmware?
2022-4-30
PatOdl
Sweden
Hi,
I have an Phantom 3 Advanced with same ESC error message, could you send me the fix?
Kr,
Patrik
2022-5-3
KargAdor
Flight distance : 427 ft
Philippines
I am having the same issue - can you also send me the link on how to fix the issue on my drone - Phantom 3 Pro.
Thanks.
2022-5-4
MarcosLanzarote
Im having the same issue with the phantom 3 professional.   Would you send over the firmware i should be using?
Thank you.
2022-5-7
MarcosLanzarote
ESC Status error message
2022-5-7
MarcosLanzarote
2022-5-7
