m80116
Flight distance : 3264131 ft
@JetSam I was more oriented to Starworshipper in my reply, but I am thinking that as well for everybody.
Maybe it's just me but when I get an error that I don't believe plausible I make sure to do everything that is my powers (provided I have the necessary confidence for doing it) to isolate the problem, especially one that's directly affecting me.
I am not saying that you both haven't received a faulty unit, I am not saying that you should do any additional tests beyond changing the props. That is DJI's duty, they should have provided a faultless unit (whih it might still be the case).
But me being me I am pretty sure that findming myself in that situation I'd determine with convincing accuracy whether the props are good or not and whether the cause is a firmware problem, which I believe not to be the case. Even if... I were given all bad props, installed and new ones, all of them warped, or flattened, or with altered pitch... I'd deliberatly try to re-mould them to increase the blade angle, stagger them on the AC and see the results.
But... anyway, to cut it short, you've done your best, you changed your props... didn't work, you can open a ticket (and you should) which in my view is your best option. Or continue flying disregarding or downgrading the firmware... but be aware you may (and you probably) have an impaired AC.
t |
