sbonev
Flight distance : 3665279 ft
Switzerland
MisterFrag Posted at 5-21 16:06
Thank you for correcting me. I’m new to DJI and use an iPhone with the controller, and assumed the two maps used the same data. If they did, one wouldn’t need to connect to a controller and aircraft at all — seems like an odd design.
yeah logic is not working the same way with DJI software unfortunately...i thought the same, but contrary to common sense those are "different" maps..and it is not clearly explained nowhere nor you can be sure how long the caching works and if there is a limit in size when it starts overwriting... |
