Winston
This isn't looking good. The extraction tools are just boring the screw heads off, and by the looks of it the crash also caused the yaw arm to bend the top base plate. I can't get it apart to see if there was any damage to the circuit board. Any chance anyone knows of a source to purchase the base + circuitry alone?
Thanks,
EDIT: Ended up drilling the heads off the screws which has allowed me to remove the top plates. There is some of the thread sticking out, so I'm going to attempt to hook on to them and twist them out, hopefully with success. I've also started to adhere the replacement flex ribbon to the replacement yaw arm. I'll keep this thread updated as I progress to hopefully a successful gimbal rebuild.
