P3 Pro Connects and starts but won't take off.
KW1162
Flight distance : 6030 ft
Hey,
Anyone have this issue?
I have checked for updates, calbrated IMU, remote control and compass.
I havent' flown in a while.
The system all connects with no errors and the P3 starts.
Finds the correct home point and says takeoff.
When I throttle up I get a slight increase in rpm, but not enough to lift off.
What am I missing?
Thanks
2020-5-25
KW1162
Somehow it got switched from Mode 2 to Mode 1 on the flight stick setting page. Switched back 2 Mode 2 and all is good. Too bad that took me 3 hours to figure out.
2020-5-25
JetSam
Flight distance : 3440476 ft
Welcome KW1162 , I would check the battery and drone connections if you haven't used it in a while , I would also check the state of the battery in the Dji go application, it must be well balanced for proper operation
2020-5-25
JetSam
2020-5-25
DJI Stephen
Hi there KW1162. I am sorry to read and know that you are having issues with your DJI Phantom 3 and it is great to know that you were able to fix the said issue. If you have any issues with DJI or with your DJI drone. Kindly please post it here at DJI Forum. Thank you and have a safe flight always.
2020-5-29
Jessy Lauren
I'm having issues with mine too. I pressed auto take off and the propellers began to to turn but one was spinning fast and the others slower. And then it never took off but my app said it did and even had the option Abdallah to bring it back to home. I tried to take off again and now nothing halogens at all, not even spinning propellers
2023-9-6
DJI Paladin
Flight distance : 318 ft
Jessy Lauren Posted at 9-6 13:17
Hi there. As electronic products are affected by technological developments and changes in usage requirements, each generation of products has a fixed life cycle. In order to continuously provide you with premium product and service experiences, DJI regularly optimizes resource allocations to promote the development and application of new products and technologies. Therefore, we have decided to stop providing support services for the Phantom 3 Series and its accessories starting on January 5, 2023. We’re sorry that the services for this product have been suspended currently and relevant technical support and after-sales repair services cannot be provided. Your understanding is highly appreciated.
2023-9-18
