Corsairoz
Flight distance : 779049 ft
DJI Stephen Posted at 6-1 03:35
Hello there Corsairoz. Thank you for reaching out. The DJI Mavic Mini has a height limitation of when flying indoors. When the said drone's GPS is weak, the safety feature of the DJI Mavic Mini will trigger and limits the height to 5 meters for safety purposes. In addition interference from other sources might have triggered the drone to move uncontrollably. In addition, the Vision System of the DJI Mavic Mini allows the aircraft to hover at low altitudes ( 0.5 to 10 m ), but the ground must have distinct textures, and there needs to be sufficient lighting. Thank you.
[view_image]
Thanks for the reply DJI Stephen
Yes, but operationally the behaviour is very different to that manual page.
I was flying in a warehouse, no GPS, a lot of light and plenty of ground texture for the downward cameras to 'see'. Yet the aircraft locked at 5m metres, not the 10 metres mentioned in your diagram. Plus the diagram refers to recommendation, not a fixed lock in the system.
So, I suspect, and this varies from your manual page, the logic is:
IF NO GPS THEN MAX Height above ground = 5.0 metres. And that's it.
So the 10 metres advice shown in the diagram is not actually available or correct.
10 metres would be more than enough for me, I just need to clear some ground obstructions (Vehicles).
Thanks
Corsairoz
