albolo
Indeed!
I did a couple more tests, and from what I can tell, the QuickShot is executed with whatever settings were last used in Video. The way things are laid out in the app makes this a little counter-intuitive, in my opinion since the resolution and FPS options are within the 'Video' menu, which is at the same level as the 'QuickShot' menu. It led me to believe that the resolution & FPS settings were only applicable to the menu item I was currently within (i.e. Video).
In practice, however, this was not the case... And all in all, it's good news, since it let's the user pic whatever they would like. I only tried playing between different resolutions, all at 30 FPS. Will try to remember to change FPS next time as well to see if that's also user-defined when running QuickShots. |
