The distance interval in meters when two photos are taken as the aircraft moves between the current waypoint and the next waypoint. The maximum value is 6,000.0. The minimum value is above 0.0 and depends on the camera type, the camera parameters and the flight speed. When the photo file format is JPEG, the time interval between two photos cannot smaller than 2 seconds. When the photo file format is RAW, the time interval between two photos cannot smaller than 10 seconds. If the input exceeds the camera's capability, the taken photos may be less than expectation. The default value is 0.0 and no photo will be taken.Only supported by flight controller firmware 3.2.10.0 or above.
I use the shootPhotoDistanceInterval for my photogrammetry algorithms. This is a great function with high accuracy for 3D missions. With this function you can limit waypoints to a minimum.
Meshroom
Metashape
You can see one of my shootings with this method on Sketchfab: Faulhorn 3D
If you prefer to see the video of the making off, you can find it here:
This function is perfectly accurate and reduce the numbers of waypoints.
I calculate the speed between 2 images for JPG with 2 seconds and for RAW with 5 seconds with a maximal speed of 8m/s to address all aircrafts.
I use two mathematical mission systems. The 3D semi spherical and the 2D flat system.
The shootPhotoDistanceInterval is very useful for photogrammetry.
