ESC Beeping (Code:30128) and Propeller rotating too fast error
12345
162713 168 2020-6-8
dpleasants
Flight distance : 17011 ft
I just received this warning for the first time today.  After reading this whole thread, I must say that I store my Mini in a different case and have never crossed the blades for storage.  Can't wait to see what DJI says about this, if they even do.
2022-9-8
Beta5K
Flight distance : 196880 ft
I wonder if aftermarket props can cause this as well
2022-9-9
madmanscam
India
This is a common issue with the new drone. You can see this video to resolve it. Its an easy fix. Nothing to worry about. Its the case thats the issue and moreover has a simple fix. Whats even better is that your drone, with this new firmware update has the capability to tell you that there is an issue that can be fixed. So nothing to be alarmed about.Click here otherwise.
https://youtu.be/JOS-FS1hnDc
2022-12-5
wee.minidrone
Flight distance : 151220 ft
Turks and Caicos Islands
Dupe
2023-1-22
wee.minidrone
Bump - any updates? Just got this error while on vacation. Rear right prop (not rear left like most in this thread). Disappointed not to be able to fly this trip but I didn't bring replacement props and I don't want to crash in the ocean
2023-1-22
Spink
Flight distance : 6224 ft
Sri Lanka
Hmm. Same issue. Except mine was the back right props. Switched them out and appears to be fixed. Fingers crossed.
2023-1-26
djiuser_Tpdv0udhXYiw
El Salvador
2023 and i have the same problem. Any new comments on this ?
2023-8-17
Sean-bumble-bee
Flight distance : 15997 ft
deleted, didn't quote the person to whom I was replying.
2023-8-17
Sean-bumble-bee
djiuser_Tpdv0udhXYiw Posted at 8-17 09:03
If you have read the thread then you know the cure, change the deformed blades.
But note replace both blades on an affected motor,  DO NOT change just one blade.
If you fly a hover at eye level in truly WINDLESS conditions and leave the drone hovering for a minute or so with no stick input then post the DAT for the flight it may be possible to identify the motor or motors with the deformed blades.
2023-8-17
12345
