Ronin-SC Release Notes (06/10/2020)
6110 17 2020-6-10
DJI Support
Flight distance : 2408 ft
South Africa
Overview:
  • Date: 2020.06.10
  • Firmware: v1.5.0.40
  • DJI Ronin App iOS: v1.2.8
  • DJI Ronin App Android: v1.2.8
  • User Manual: v1.2
What’s New?
  • Added photo capture, video recording, autofocus, and focus pull support for Fujifilm X-T4 cameras with supported X mount lenses using the Multi-Camera Control Cable (Type-C). Requires Fujifilm X-T4 firmware v1.0 or later. To use autofocus on the Fujifilm X-T4, press halfway down on the camera control button of the gimbal. Note that the camera is unable to auto focus in video recording mode.
  • Added photo capture, video recording, and autofocus for Fujifilm X-T4 and x100v cameras using the Camera Control Cable (RSS-F). To use autofocus, press halfway down on the camera control button of the gimbal.
  • Added photo capture, video recording, autofocus, and focus pull support for Canon EOS 90D cameras with supported EF mount lenses using the Multi-Camera Control Cable (Type-C+Type-C to Micro USB). To use autofocus on the Canon EOS 90D, press halfway down on the camera control button of the gimbal.
  • Fixed issue: Gimbal did not follow the preset path when using Track in Underslung mode.
  • Optimized gimbal performance when the deadband is set to low.
Notes:
  • Update the firmware through the DJI Ronin app. Make sure that the DJI Ronin app is the latest version when updating the firmware.
  • If Ronin-SC has a camera attached and is turned on while updating the firmware, make sure to protect the camera and lens, as the motors will shut off during the update.
  • If the firmware update fails, restart Ronin-SC and retry.
2020-6-10
syue87gmail.com
Can you also add USB C support for Fujifilm X-T30?
2020-6-10
kimtacos
please work on a firmware update to enable compatibility with Samsung NX30 at least to allow recording button to work.  thank you
2020-6-10
KlooGee
Flight distance : 14851519 ft
Woohoo!  Full Canon 90D support!
2020-6-10
David van Jaarsveld
Belgium
Great job supporting the Fujifilm X-T4 so fast, thanks!
2020-6-10
BallGame72
Thanks for all the updates.
2020-6-15
F4PukinDog
Support for Canon EOS 70D.  Please advise if there is a possibility to update the SC to interface with the 70D.  The camera balances out very well with the SC and this model still has lots of service life left.  The Ronin S shows compatibility and  my expectation is that the SC can likewise be engineered to support the 70D.
2020-6-27
MikeH2020
Please implement support of Canon Powershot G5X Mark II. In principal it is the same camera as the Powershot G7X Mark III, which is already supported, so it should be easy to implement.
2020-7-8
Xairoo
Flight distance : 48130 ft
Switzerland
Now my focus wheels double blinks red. Manual says firmware update is required. Lol... How?! All the applications (Win/Mac) are only for the Ronin, MX, S, ... but not for the SC. Or I didn't see it.
I updated my Roninc SC with iOS.
2020-7-9
djiuser_t2OSchz4mJDV
Dose anyone know if the Nikon D7500 dslr and 18 -140 mm Nikon lens is compatible with the Ronin SC
2020-7-29
sobeek
Poland
When are you planning to support USB-C for FUJI X-T30? FUJIFILM X-T30 is ready for that. Thanks!
2020-8-3
griffdude13
Pan Axis won't recognize as balanced when it is, please address this in the next update.
2020-8-6
Tom John Lopez
United Arab Emirates
How about some support for Canon M6? I already contacted your customer service and they said they will inform your technical department regarding with my camera model. Just tell me if you can't support the camera so that I can sell the gimbal. Thanks
2020-8-16
fans8cac27e7
Can't get Ronin SC to work with my Canon M50. The camera will not go into record from the record button on Gimbal.
Can anyone help with suggestions?
Thank you
2020-8-20
jayemedia
Please implement support of the Canon EOS R6. The camera just came out last month but please make another firmware update so my Ronin SC is compatible with my camera
2020-9-3
tricks
hello, I recently attempted to update my ronin sc to 1.5.0.40 but it failed! now its unresponsive. I've tried everything you suggest, resetting, different phone, check bluetooth everything I can think of but its just not working. had no response via email from support.
2020-9-10
tricks
Having major issue with the latest firmware upgrade, it failed whilst uploading and now will not do anything, I can connect through Bluetooth but will not let me do any new firmware or reset. It’s just dead won’t do anything and DJI are not responding! I cannot find any info online anywhere about this problem. Can anyone help.?
I’m good with tech and have tried all the usual things,
Reset phone, reset app, check Bluetooth.. different phone but the update just keeps failing. Getting very frustrated with it.
2020-9-11
djiuser_juJWfHiXSaZl
Flight distance : 28907 ft
Turkey
we got dji ronin sc but i'm in shock, olympus em1 works with mark 3 why
2021-1-16
