No video transmission from x7
1575 6 2020-6-12
Mike9129
Flight distance : 4112812 ft
Hi,
Wondering if anyone could help with this
Was doing a job yesterday, everything was working fine, not problems
On what was to be the last flight, I changed the battery pack in the drone as normal, turned it back on, and it would no longer transmit video from the x7 to the controller.
it wasnt dropped, it didnt happen in flight, not landed hard, etc etc
Im still getting the video feed from the FPV camera to the controller, but nothing from the main camera (video feed or histogram)
Any ideas whats the cause or if its a straight fowards fix?
Thanks
Michael
2020-6-12
flyingfun
Flight distance : 2551998 ft
Luxembourg
Did you try reseat the camera ?
2020-6-12
Mike9129
flyingfun Posted at 6-12 00:45
Hey,
Yeah, so far tried re-seating the camera, changing the lens, wiping the contacts between the camera and body, re-seating batteries, different batteries, restarting the controller/crystalsky, re-pairing the controller.
2020-6-12
flyingfun
Luxembourg
Did you try to remove the lens and back on ?
2020-6-12
Mike9129
flyingfun Posted at 6-12 05:48
Turned out it was water damage to the processor on the drone was causing problems.
I sent it back to DJI and had it replaced
2020-8-7
Gazza1973
Switzerland
Hi everybody,
i ave the same problem as described above, I try whole solution as Mike 9129, nothing happened
what should I do?
thank you
2021-1-6
Matthew Dobrski
Flight distance : 1831050 ft
Gazza1973 Posted at 1-6 09:01
Hi everybody,
what should I do?
Do exactly the same: open the repair ticket with DJI ...
2021-1-8
