DJI Fly 1.1.5 is out
12Next >
6668 40 2020-6-15
Donsir_LTU
Flight distance : 1043940 ft
Lithuania
Today I've got DJI Fly 1.1.5 (for Android) Cant see any difference/features
2020-6-15
Skydiver021
Serbia
Same as what's new description like in 1.1.4
2020-6-15
A J
Flight distance : 13838848 ft
Probably debugged 1.1.4
2020-6-16
sbonev
Flight distance : 3665279 ft
Switzerland
probably because of mavic air 2 firmware upgrade - they either screwed something and now are fixing it or adding new functionality made available through the firmware.i just hope they won't screw something on the mini...
2020-6-16
shadowx.jb
Flight distance : 1511047 ft
Czechia
What’s New
- Updates icons for the remote controller signal and GPS signal.
- Adds Target Scanning toggle in Control settings. When enabled, aircraft will automatically scan and display targets in the Camera View (only compatible with Mavic Air 2).
- Free Hyperlapse mode now supports the Spotlight function. After users drag a box to select a target, the target automatically stays centered in the shot (only compatible with Mavic Air 2).
- Fixes crashing issues and improves app stability.
2020-6-16
sbonev
Switzerland
shadowx.jb Posted at 6-16 01:52
What’s New
this was for v1.1.4....nobody knows what is in 1.1.5 apart from DJI devs
2020-6-16
shadowx.jb
Czechia
sbonev Posted at 6-16 02:27
I'm sorry, but this is displayed in google play.
2020-6-16
Droneflier
Flight distance : 1811322 ft
South Africa
2020-6-16
Droneflier
South Africa
DJI Fly was designed to help pilots fly drones with ease.
(DJI Fly is compatible with Mavic Air 2 and Mavic Mini aircraft).
What’s great about DJI Fly?
· Intuitive UI and expansive Camera View.
· Easy-to-follow Flight Tutorials to help you get started.
· New search function for discovering nearby Fly Spots and GEO zones.
· Advanced Editor platform with tools and templates for quick editing and sharing work.
2020-6-16
djiuser_uL7tqTh06ZWo
Flight distance : 358770 ft
Indonesia
Droneflier Posted at 6-16 04:41
Simple thing they cant done..the icon color of signal , sat ,  batt %  still in white...its s*uck to see when the camera upper is sky ,  make the icon disepear
2020-6-16
Tentoes
Flight distance : 6018255 ft
Just updated mine. I'll see this evening.
2020-6-16
Skydiver021
Serbia
djiuser_uL7tqTh06ZWo Posted at 6-16 05:34
I can't believe it's so hard to put a transparent bar under the icons in the top row. DJI please do it.
2020-6-16
MartellXO
Flight distance : 37582 ft
Russia
I noticed, that battery icon becomes red below 30% now. As I remember, before it was red below 20%.
Also at 7% I got a message something like this: "Battery power is limited. Drone performance reduced for safe flight. Please go home."
I didn't see it before update 1.1.5 Maybe I didn't have experience with 7%
2020-6-16
K6CCC
Flight distance : 651683 ft
Updated DJI Fly app on my Motorola G7 Power and will take it up for a flight at the house late this afternoon...
2020-6-16
3Recon
Flight distance : 4175541 ft
MartellXO Posted at 6-16 08:52
Also at 7% I got a message something like this: "Battery power is limited. Drone performance limited for safe flight. Please go home." I didn't see it before update 1.1.5 Maybe I didn't have experience with 7%
You want to be catching or landing at 10% because the Mini is trying to do a force landing.
2020-6-16
MartellXO
Russia
3Recon Posted at 6-16 09:37
Mavic Mini start force landing after 5%. But even at this moment you still can push it up by left stick. Of course, such low battery condition shouldn't be in the normal flights, but it is good to know for emergency needs.
2020-6-16
3Recon
Never looked that close while dropping over tree line toward landing zone. Doesn't happen all the time, think goodness. Just wanted to give you a heads up but sounds like you've experienced it yourself
Sorry to repeat you.
By the Fly app sharing same software with Air 2 and the Mini I'm sure we'll get some drippings as they fine tune the 2. It happened in the editor.
Skyward Mini's
2020-6-16
Skydiver021
Serbia
Battery icon becomes red below 30% from 1.1.4 version.
2020-6-16
Guorium
Flight distance : 513061 ft
Skydiver021 Posted at 6-16 14:15
how about the incessant beep?
2020-6-16
3Recon
It's so peaceful as we enjoy flying the Mini, not a care except for piloting your Mini and then BEEP, BEEP and you have this filling everybody and thing is watching you.... well maybe not that bad or is it.
I wonder if connecting a set of head sets either by Bluetooth or wired would help. Never ready checked if it's using mobile device speaker. If I can get up tomorrow I'll try but if someone gets to first, share.
2020-6-16
Skydiver021
Serbia
Guorium Posted at 6-16 17:30
On 30% there is no beeping, I did not tested lower battery level under 20% and less because the weather is bad and I leave battery on 28-29% in the box.
2020-6-16
virtual
Flight distance : 4897142 ft
Czechia
3Recon Posted at 6-16 21:10
I believe there's a speaker on remote...
2020-6-17
DroneroGT
Flight distance : 401545 ft
Guatemala
Update 1.1.5 was for all Mavic Air 2 updates.
It's a pity that DJI left the Mavic Mini behind so quickly and that they won't get any updates out of it anymore.
2020-6-17
TDZHDTV
Flight distance : 2068550 ft
DroneroGT Posted at 6-17 01:20
and what factual source did you determine the Mini would be no longer supported?
2020-6-17
sbonev
Switzerland
TDZHDTV Posted at 6-17 02:21
well latest 4 or more iterations are pretty much bugfixes and functionality for the air 2, i am pretty sure in the future will be the same. most will be for the air 2 as newest and more expensive drone. the mini is at more or less stable version of the software so i doubt much functionality will be release if any at all... will be lucky if they fix the existing annoying bugs...probably if they happen to the air 2 owners only. they cannot get rid of the ridiculous bluetooth disable issue which is present since the beginning and not to mention the icons, so i won't put my hopes up for anything...
2020-6-17
Niflheim The Dude
Flight distance : 533048 ft
Romania
Well giving the fact that the  sdk  will be released  around  the 13th of july  2020 , we may be in for a surprise.  Also if no features are  added, with  the  sdk we  still have a  chance  for  3rd party apps (check out litchi) to implement what  is missing  (active  track, waypoint etc)
2020-6-17
contarex
K6CCC Posted at 6-16 09:09
Hi K6CCC, could you kindly let me know if the actual DJI Fly version works with the Motorola G7 Power? I've the version 4/64, model XT1955-4 dual sim.
It would be really a help, I would like to buy the Mavic Mini but I am blocked by the fact that I read about its incompatibilities with DJI Fly.
Thank you!
2020-6-20
DJI Stephen
Hello there Donsir_LTU. Thank you for reaching out and for the inquiry. The Android DJI Fly V1.1.5 has been released on June 16, 2020. Kindly please refer to the post of Droneflier on post #9 for the list of What’s New on the said DJI Fly application version. Thank you.
2020-6-21
K6CCC
contarex Posted at 6-20 02:26
I assume you are asking about my phone specifically.  My phone is a moto g(7) power.  I can't find anyplace that lists numbers similar to what you posted.  As for Android firmware version, mine is system 9 build number PDOS29.114-134-15  I have DJI fly version 1.1.5 as downloaded from the Google Play Store.
I don't know if that helped...
2020-6-22
3Recon
virtual Posted at 6-17 00:38
Working instead of flying around my place but took a battery break and forgot to disconnect Bluetooth ear buds while listen to tunes. All commands came through loud and clear.
2020-6-22
Goldbuster`s
Austria
absolutely
2020-6-22
virtual
Czechia
3Recon Posted at 6-22 18:43
So is the remote speaker disconnected/all sounds (and annoying alarm) redirected to headphones?
2020-6-23
3Recon
Sorry didn't do a complete test the point I did experience  was at beginning of flight setting home pointand activating RTH. What I need to do on my next flight is mute my device speaker and listen if that Beep is like you say just in the remote.
2020-6-23
contarex
K6CCC Posted at 6-22 10:27
Thanks for your reply and the useful info, I only see it now. That's right, I was asking for info for this phone that I also have.
You can find the version fo your phone in the system info. In any case, just for your info, XT1955-4 is the G7 power dual sim and XT1955-2 is the G7 power single sim. However, I don't think it makes a difference while using the app.
My Android 9 is build number PDOS29.114-134-13 (probably the difference is due to the European version).
Going beyond these technical info, from what I understand you can use the app well, which is a good thing! I'll try soon the Mini of a friend with my phone before buying it.
2020-6-25
22340179
Flight distance : 6763835 ft
I flew with the new update yesterday. The remote still beeps at 20% and under.
2020-6-25
Guorium
22340179 Posted at 6-25 12:30
Thanks for the update
2020-6-25
THarjanto
Flight distance : 32946 ft
Indonesia
I have Mavic Air2 . I can connect it with  my Ipad Air 2 properly  but  not for my  Samsung A9 Pro  (Android Version 8.00 , 64bit  CPU  , RAM 4GB  , Internal memory 32GB ) .
Does DJI fly  need higher android version ?
Thanks in advance
2020-7-1
Tiago Dias
Flight distance : 34987 ft
Portugal
Dji Fly (1.1.5) for mavic mini d'ont work in iphone. The application opens and closes.
2020-7-10
InvisibleName 7
Flight distance : 795653 ft
Tiago Dias Posted at 7-10 04:43
Join the club! Loads of iOS users are having the same problem.  Try it in Airplane mode, should work OK (apparently, it's something to do with Facebook - go figure!!)
2020-7-10
K6CCC
InvisibleName 7 Posted at 7-10 04:46
I normally use my android, but have tested 1.1.5 on my iCrapPhone 8 and it works fine.  However I don't have facecrap installed on anything.
2020-7-10
12Next >
