Rustic17
Flight distance : 2733760 ft
When you say "firmware updates will also be available..." it probably should say "may be available". In other DJI products when you updated the firmware it seems to me the drone version number might change but the RC might not. I think that's accurate. When the Fly app says there's an update, you might not know if it's for the MA2 or RC. You can always go to the Menu>About page and see what components need updating. When you install a firmware update the RC and MA2 have to have power and the Fly app must be on the Home page to select Install and they all have to be connected as normal. On the app as you power up, you see the RC connect followed by the MA2. Once you've installed the update the RC, MA2 and battery in the MA2 are updated (or not, if the update only pertains to one component). You then need to put each of your other batteries in the MA2 one at a time and the prompt to install firmware will display, if needed. The Fly app has to be updated through your mobile device.
