HoosierFlyer
Flight distance : 131516 ft
DJI Natalia Posted at 6-18 04:18
Hi there, sorry for that case happened. Kindly please check the below methods:
1. In tropical areas and high-temperature outdoor environments in summer, if the temperature of the main controller exceeds the temperature alarm value after a long period of flight, it is normal that the DJI Fly app prompts “Aircraft processor overheated”. In this case, the aircraft has to be powered off, and flight cannot be continued until the aircraft has cooled down. It is recommended that users fly their aircraft within the recommended operating temperature range (The operating temperature of the Mavic Air 2 aircraft is from -10 ° C to 40 ° C).
2. The aircraft is flying in a normal-temperature environment:
Actually, the drone can be taken apart and you can re-apply the proper thermal paste and never see this issue again.
Sending it back to DJI is what they want you to do, but not required, and certainly not the fastest way to resolve the issue. |
